It is currently Thu Aug 21, 2025 1:08 am
PostPosted: Mon Oct 31, 2005 4:28 pm
hi everyone,i had the brakes on boris adjusted recently and under heavy brakeing he is pulling to the left,bit scary,its reallt noticeable,is this normal thanks :P
PostPosted: Mon Oct 31, 2005 4:31 pm
Subject:boris pulling to the right
so which way is he pullin? :P i would say that isnt normal :?
matt
PostPosted: Mon Oct 31, 2005 4:35 pm
Drums or discs? If it's drums could be they need adjusting.
PostPosted: Mon Oct 31, 2005 4:38 pm
sounds like a sticking piston or incorrect adjustment :?
PostPosted: Mon Oct 31, 2005 4:39 pm
i got a git mixed up there :roll: its to the left,drum brakes
PostPosted: Mon Oct 31, 2005 4:44 pm
sticking piston,im definatly ignorant as to the way of the mini,there are pistons near the brakes,the brakes were adjusted by some peaple i know at the local gararge :oops: probably not the best place to get them don could they be to tight,theres a bit of a squealing sound when brakeing as well
PostPosted: Mon Oct 31, 2005 4:48 pm
the brakes are hydraulic, so there is a hydraulic piston which pushes the brake shoes into contact with the inside of the drum, if the piston sticks or seizes which happens, the shoe won't return to its proper position and may stick on..
if the adjustment is incorrect, the left shoes will contact the left drum before the ones on the right.
the brakes may even up if you press them harder or pump them, that should give a bit of an idea
PostPosted: Mon Oct 31, 2005 4:58 pm
that makes sense,so how can the adjustment be incorrect,from what iv read in my mini manuel the brakes are tightned untill the wheel hub wont move and then released untill the wheele moves freely,
PostPosted: Mon Oct 31, 2005 5:11 pm
yeah which is why it could be your wheel cylinders?
