yeah should be a good one, but no can do on the 17th its my brother wedding.
as for dyno, absolutley straight to castle hill, thsi turbo setup will remain till the 8 port is done.
wel i just got back from GR's and bumped into the good doc there too, we all had a good chat and GR is checking over my head and looking at my guides and valves etc, he has given me a tool so i can now measure my piston height in the block to work out my comp ratio and work out how much a have to remove of the pistons to achieve the desired comp ratio of 7.5:1.
we also spoke about cams and a few other ideas from GR too.
should be able to take pistons to him on monday and then have them all back and fitted to the rods by the week after that.
ok update, finally all my bits from avonbar inc cam kit have arrived, i have also had to go back to a std stroke crank to try and get my comp ratio to a better level, i am aiming at 7.5:1, so the capacity now is a 1293cc, as the motor is currently at 8.8:1 i need to find another 6cc of total chamber volume, GR is going to do a little more head cutting plus a small amount of maching in the pistons to find that extra combustion chamber volume, so the dummy build has started and all is good, so i will go to GR on monday and give him some bits and then a weel later will start the final build up.
been too long having withdrawals
100% Pure A Series Turbo
