It is currently Sun Jul 20, 2025 8:50 am
PostPosted: Fri Nov 11, 2005 9:45 am
no.
But the local bottle shop is full of products that will help parents with there own teething relief. :wink:
Aaron
PostPosted: Mon Nov 14, 2005 7:19 pm
Owen's got a New Ride
Yep its his new sports bed In Morris..He can put his finger up to all that follow to close
$325 and peice of mind..Sue Has here car back and we can take Owen around with us.
Time for him to experince it :wink:
PostPosted: Mon Nov 14, 2005 8:24 pm
how hard is it to get him into the seat in that position?
PostPosted: Mon Nov 14, 2005 8:33 pm
So, what do you get for your $325 then? You already owned the capsule...?? :?
PostPosted: Mon Nov 14, 2005 8:58 pm
gafmo wrote:
yer fixing point on the parcel shelf will be close to the seat as the PO put 9x6 speaker holes and a Subby
I think I'e mentioned it before, but holes in the parcel shelf are an MOT/WOF failure in NZ.
There is not only the reinforcing plate for the seatbelt, but the child restraint needs to be mounted to a strengthened part of the shell. Most modern cars have the seat restraint bolt holes there already, and the parts required are fairly substantial - they're not just mild steel.
The other aspect is not only your child, but any subsequent owners may rely on your handiwork, so getting a pro to do it is the only reasonable way, so $350 isn't extortionate.
PostPosted: Mon Nov 14, 2005 9:01 pm
I was thinking the same thing. Danielle has a similar seat and with the four door cars we can sit right beside her as we put her in.
sue will have to climb into the back with him in order to strap him in - make sure she is forwarned. :D
PostPosted: Mon Nov 14, 2005 11:12 pm
Years ago!!!! When our first came along, I had a K and I copied the hole positions of a clubby and with backing plates of the same size installed a LAP belt only. Put the car seat fitting in the rear parcel shelf and Bob's your uncle.
68 Deluxe. All the Options and Mods. Bling-Bling.
PostPosted: Tue Nov 15, 2005 6:29 am
Cheers guys :wink: Yep, Sue is aware she will be required to get into the back seat to put Owen in, she has test run it already.
Sue will not, repeat Will Not drive our Bigger Car Alfa 75 as she loves her Mini. anyway I won't him to grow up on mini's anyway
Regarding to the parcel shelf...yep thats why I got Littles to do it for us. If I had done it, it would not have be approved and possible insurance void if anything happened :!:
PostPosted: Tue Nov 15, 2005 8:21 am
Slow-Po
Just beware that as the little one starts to pack on the kilos, the risk of a lower back injury will increase (that's why 4wd are popular with families, you can stand upright and strap the kids in).
You may want to try a technique in which you can slide him down into the seat from the outside, and then climb in to strap him in. :D
PostPosted: Tue Nov 15, 2005 8:25 am
And when they get to 2 years old, a hand held Tazer gun is also useful.
PostPosted: Tue Nov 15, 2005 9:01 am
Slow-Po
^^^ :lol: :lol:
PostPosted: Tue Nov 15, 2005 9:02 am
High heel ninja
Kev, i can't belive you said strap him in with race tape, i was thinking the same thing before i read your post. Does this make us evil??????
Doogie
Race tape fixes everything
