It is currently Fri Aug 01, 2025 2:05 am
 Post subject: Van hinges
PostPosted: Wed Nov 23, 2005 8:37 pm
I have a 68 morris van and the rear door hinges were taken off a while ago and once putting them back on, i have no idea where which one goes... So i have a pic of all 4 sitting on the ground could any one maby advise me to where which one goes? Does the nut sit at the bottom of the hinge or does the pan headed end with the slot in it sit at the bottom? Any one have a pic of the rear of their van that they could post?
Daniel
Life's a garden.... Dig It!
PostPosted: Wed Nov 23, 2005 8:39 pm
PostPosted: Wed Nov 23, 2005 8:43 pm
email sending now...
mine is a 74 leyland van so it might be different i am sure someonelse can advise on this though
matt
PostPosted: Wed Nov 23, 2005 8:57 pm
NAV-MAN
my passenger side top hinge is very loose. Can they be re bushed like door hinges?
PostPosted: Thu Nov 24, 2005 5:38 am
Nuts are on the bottom with the Pan Heads on top :wink:
PostPosted: Thu Nov 24, 2005 5:23 pm
Ok here's a pic from Matt... Thanks
PostPosted: Thu Nov 24, 2005 5:27 pm
Sorta makes sense you don't want your doors to drop of if the nuts come undone :shock:
Roads need more corners
PostPosted: Thu Nov 24, 2005 5:32 pm
Yeah thats right, i though i had them all in the right order but they dont seem the doors dont seem to fit properly,
some how the van must have warped...
This is a pic of the top left hinge as you are looking at the back...
This is one of the topr right
See the difference in the gap between the door and the rear of the van?
PostPosted: Thu Nov 24, 2005 5:34 pm
Maybe swap them top to bottom :idea:
PostPosted: Thu Nov 24, 2005 5:39 pm
Yeah that seems like the next step, there isnt that many ways they can go in.. And if that dosnt fix it then ill just
have to move the hinges to suit where the door fits. There has been alot of welding in the van so that probably
caused it...
PostPosted: Thu Nov 24, 2005 5:44 pm
NAV-MAN
Do the doors have an even gap down the middle?
The hinges could be a bit knackered as well
I don't think even panel gaps is a mini's strong point
A quick look at nav's doors
PostPosted: Thu Nov 24, 2005 5:47 pm
Have a look on the back of the hinges - they have a code stamped into them
LL = lower left
UR = Upper right
etc.
At least that the case on the roundie PV I am restoring.
PostPosted: Thu Nov 24, 2005 6:01 pm
From this pic the gaps dont look so bad, but they are out, and the doors clash in the middle. And these hinges
are new so they shouldnt be stuffed, and ive looked at the hinges and there is some markings on the back but
nothin that lets me know what hinge is what...
PostPosted: Thu Nov 24, 2005 6:02 pm
I havent taken my doors off yet guys but do you have a spring that runs inside the Hinges and a washer with an extra bit that goes inside Also :idea:
PostPosted: Thu Nov 24, 2005 6:56 pm
Yeah i have 4 new hinges. The first pic is one of the old ones, which i had to replace cos one of those bolts snapped
