It is currently Thu Jul 03, 2025 3:00 pm
PostPosted: Sun Nov 27, 2005 11:22 pm
NAV-MAN
4 synchro remote and rod change (not A+)
covers are the same. :wink:
How do i tell if i have a 4 synchro remote box? I'm unsure of what they came out of
PostPosted: Mon Nov 28, 2005 11:30 am
Did anyone say Ben Dover. Please to meet you Ben!
Dan
Money! easy come, easy go.
PostPosted: Mon Nov 28, 2005 11:59 am
OMG!! That is the scariest Sump Gremlin I have ever seen!!! :shock: :shock:
PostPosted: Mon Nov 28, 2005 12:41 pm
NAV-MAN
^^^ hehe good one jam
i don't seem to be able to slpit the box from the block
anyone have any tricks to split it off?
PostPosted: Mon Nov 28, 2005 6:51 pm
Make sure ALL bolts are out including the 2 behind the engine front plate. Then stick a big screwdriver between rear main bearing cap and idler web, and lever it up, gently.
PostPosted: Mon Nov 28, 2005 7:46 pm
Mostly they are bolts that go into the block through the gearbox mounting web at the top of the gearbox.
However, occasionally the factory puts in a threaded stud with a nut on it and when you go separate the box it gets caught.
I have occasionally had to drift out the two locating dowels before the box would come away cleanly. As Doc said - make sure you have removed the two bolts behind the engine plate which is behind the bottom (harmonic) pulley.
Do not do not do not - insert a screw driver between the mating surfaces of of the gearbox and the block - its recipe for oild leaks. Under the rear main bearing is okay
PostPosted: Mon Nov 28, 2005 8:26 pm
Yukky
PostPosted: Tue Nov 29, 2005 9:51 am
NAV-MAN
Don't you just hate it when you forget one measly bolt :oops: :lol:
I had a look at my promary gear and its no good either i think
These bits
came off the clutch end of the primary gear.
PostPosted: Tue Nov 29, 2005 10:16 am
looks nasty, but at least you have found this and can fix it!
Lucky you didn't drive any longer than you has already!
PostPosted: Tue Nov 29, 2005 10:22 am
NAV-MAN
it's a mini, it will break something sooner or later :roll:
I had 2 years of trouble free before this, so on average i'm doing pretty well i think.
The box is off to Matt read to be gazed upon with experienced eyes and new parts fitted if required....... ok new parts will most likey be fitted.
