It is currently Wed Jul 30, 2025 11:58 pm
PostPosted: Wed Nov 30, 2005 10:19 pm
I recently fitted a 12g295 head to my 850 and also found a set of twin 1.25's for it, Does anyone know of the right needles and springs to use as a starting point.
Also has anyone had problems fitting LCB's to mini's with rubber/plastic uni's.
Mine dont clear the UNI.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Thu Dec 01, 2005 4:41 am
Is bloody close on mine millimeters once the intermediate pipe is on and all bolted up. No room for worn rubbers or engine movement.
steve
 Post subject: mini
PostPosted: Thu Dec 01, 2005 7:36 am
mine wont even spin.
Any ideas with twin su's on an 850
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Thu Dec 01, 2005 6:18 pm
Vizard recommends,
Blue spring and E3 neddle for 850 + modified big valve 998 Cooper head + full race cam + extractor's
or
Blue spring and M neddle for any thing smaller
Pete
PostPosted: Sun Dec 04, 2005 8:17 pm
Did anyone come to the bottom of the 'mine wont even spin' problem. I thought i had plenty of room, but no... they wouldnt spin at all.
Since then i have torqued up the wheel nut and it is much better, but still, VERY close.
No room for engine movement?? I only have 1 stabiliser, there isheaps!!
Any tricks?
PostPosted: Sun Dec 04, 2005 9:31 pm
re the engine movement- if fitting an LCB etc you have taken away the 850's 2nd most important steady- the 1 piece exhaust system... and you will probably have lots of leak problems where the engine pipe joins the LCB.
No, I am not joking- I ran one for years. :lol:
A lower steady (or a top Clubby one at least) is a good addition.
re the room problem at the U/J, I would use a freeflow type instead- its single downpipe gives you a bit more room there.
PostPosted: Mon Dec 05, 2005 11:21 am
My knuckle bolts are still hitting exhaust (exhaust not yet bolted up, but i have it sitting on 'things' in about the right spot.
Also slightly off topic, but sort of attachments are used to mount exhaust at these points in pic.
Fanks :)
PostPosted: Mon Dec 05, 2005 4:53 pm
I was just wondering beccausee other cars i have, have a rubber suspender for the rear of the exhaust not a solid mount. I don want to fit the wrong type!
Also, where do these 'extra' engine steadys bolt onto the engine and firewall/
The engine i have is an 1100 from a van (i think it is a clubby van)i would assume this needs more streadys, cause it rocks about a bit :")
PostPosted: Mon Dec 05, 2005 6:51 pm
the Clubby top steady goes from a bracket on the firewall (where heater hoses go in, or LHD master cylinders mount) to a bracket under the thermostat housing.
There are 2 different ones here depending whether it's a smallbore or 1275 head.
