It is currently Mon Aug 04, 2025 1:42 am
 Post subject: HIF carby users
PostPosted: Sun Dec 11, 2005 7:25 pm
All you guys running HIF carbs on your 1098's ( I can think of at least 2 )....what needle do you have?
I stripped mine down yetserday and cleaned it up Looks ---> 8) and only cost 0.01 remember :wink:
It has an ADS needle in it. Not sure if this is right.
I asked SUMidel and they said they would get back to me......WEEKS AGO :x
Anyone??
PostPosted: Sun Dec 11, 2005 7:43 pm
I'll have to tell you tomorrow..as I can't see in this light in the Den or the Garage :wink:
PostPosted: Sun Dec 11, 2005 7:53 pm
well i just went out side with a tourch then brought the dashpot inside and had a look and it says BDD on mine
edit my hif44 has a 0.100'' needle
hif38 is a 0.090'' needle?
PostPosted: Sun Dec 11, 2005 8:15 pm
BDD is one rich puppy compared to my ADS! :shock:
PostPosted: Sun Dec 11, 2005 8:25 pm
I'm using a BBZ on 1132.
Pete
PostPosted: Sun Dec 11, 2005 9:46 pm
you tried winsu website anton?
PostPosted: Mon Dec 12, 2005 3:49 am
Isnt ADS a standard Rover Metro needle?
PostPosted: Mon Dec 12, 2005 4:55 am
Havent checked the one in Morris yet but the one I had prior was a BDP.
Will check the one thats in thier this after noon for you :wink:
PostPosted: Mon Dec 12, 2005 10:16 am
BDD, wow that is the std Metro Turbo needle, mine has been fairly modded compared to the std needle but i would have thought the BDD on a 1098 is way way way to rich, but if it works leave it hey
100% Pure A Series Turbo
PostPosted: Mon Dec 12, 2005 2:59 pm
BDL is a std mg metro needle and a BEJ or BER is the economy nail they use.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Mon Dec 12, 2005 3:21 pm
BDD is STD metro TURBO one
PostPosted: Mon Dec 26, 2005 10:17 pm
No idea.....but when using WinSU, and selecting EVERYTHING for a standard 998, I get a needle suggested that is a TON richer than the ADS.
My motor is now running with this ADS needle, and its soooooo freakin pissweak. I would love to know what type of motor would suit this needle.
Anyway....might drop in to GR this week for a new suggestion.
PostPosted: Tue Dec 27, 2005 6:55 am
Question to you are youi sure its a HIF44 and not a HIF38 as they look almost identical but they take different size needles.
The ADS in a HIF44 will flood the motor constantly as the needle is for a 90thou jet and the car will definatly not run right.
check the hole size at the back of the carb will tell you more.
PostPosted: Tue Dec 27, 2005 7:06 am
I am sure its a HIF38 :wink:
PostPosted: Tue Dec 27, 2005 1:03 pm
my suggestion is to buy my 45DHLA dellorto, already has 32mm venturis and jetted for a stock 1098. needs a bit of bling for that gold engine though :wink:
let me know when you are going down, i've got to chat with him as well.
michael
