you need to talk with someone about the intended use for the car
that person should be a mini specialist with plenty of years of experience building & servicing minis,,,don`t just go to Joe Blow mechanic, they will have no idea
a full rebuilt 1275cc donk (to whatever size) should be completed as a """"package"""
if you go out & buy some go fast bits & just bung them together then the engine just won`t be what it could have been if it were built as a """Package"""
i would also look at doing up the gearbox & drop-gears to make sure all is nice there too,,,you won`t want a shabby gearbox spewing metal slithers up into your oil pump & crank bearings wrecking your nice new donk now would you???????????
flat top istons were originally intended for race use, the comp ratio is needed to be kept at about 10:1 (ish) maximum for road use,,,much above that & you have a dam good chance of detination inside the combustion chambers which will eat away at your head gasket & piston & also hammer piston ring lands & crank bearings,,,so basically it`s not very good to have pinging/pinking/detonation , a very well sorted cyl head , carb & distributor & exhaust system as a package is a must if higher comp ratios are to be used for road engines on pump fuel,,,Av-Gas for race engines is a whole different ball game & not allowed to be used on the road.
That said,,,the bigger engines & engines with bigger cam shaft profiles can get away with a slightly higher comp ratio,,,in fact big cams really NEED big comp ratio for them to work properly, but again these sorts of things are set for more of a race engine than a roady
Road donks are just that, ROAD USE,,,track or club race engines can be set with much "sportier" cam profiles & higher comp ratios & bigger valves etc, but at a cost of low down drivability & also premature engine wear from constant high revs etc etc etc
Big cams will need strong valve springs which in turn can hold an engines power down somewhat & also tend to wear things out very much quicker, like cams, lifters, valves & rockers etc etc etc
compromise is what`s needed here & you will need to look at what you`re going to use the car for , before undertaking an engine build with go fast parts
i`d expect you should be paying about $4500 for a complete roady re-build including the box
race engines are much higher cost than that
happy???????????
_________________ No offence intended here but--> anyone writing a book about minis 30 years ago may not have experienced such worn or stuffed-with components as we are finding these days.
