It is currently Sat Jul 19, 2025 7:27 pm
 Post subject: which needle for me?
PostPosted: Thu Dec 22, 2005 10:40 am
ok, so i did a search and couldn't find much so im askin......
Which needle should i have in my 1.5in SU?
All thats been done to the car is- LCB's, 1.75in exhaust, an rc40 muffler and a ramflo filter
The needle in there at the moment is ADF (standard)
Grateful for any help
EDIT: the motor is an 1100 :oops:
PostPosted: Thu Dec 22, 2005 12:59 pm
Heya
WIN SU suggests u should use
BDE
and possibly try
BEJ
BFY
1978 Leyland clubman S.
PostPosted: Thu Dec 22, 2005 1:17 pm
ta, ill give it a go
PostPosted: Thu Dec 22, 2005 3:32 pm
winsu is severly wrong, B-series needles are for HS6 carbs, i have a HS4. Perhaps not the BDE then......
PostPosted: Thu Dec 22, 2005 3:39 pm
there is a drop down tab to select needles for the HS4...
and thats what i did..
i put ur engine specs through, and it came out with BDE
id give it a go
PostPosted: Thu Dec 22, 2005 6:01 pm
Unfortunately - although you selected a HS4 carby, the BDE is a needle for the HS6 and HIF range of carbies.
WinSu has some development problems at times
PostPosted: Thu Dec 22, 2005 9:06 pm
thats what i thought^^. Ill keep looking around, might ring a few places and see what happens.
PostPosted: Thu Dec 22, 2005 9:09 pm
What Mike means is,
The BDE won't even go in there, as it's made to fit in a 0.100" jet. Your HS4 has 0.090" jet.....!
PostPosted: Thu Dec 22, 2005 9:16 pm
yea, i need a needle starting with 'A' from what i gather, not 'B'. someone said an AAN or AAM (cant remember which) would be what i want.
PostPosted: Thu Dec 22, 2005 9:53 pm
Give Silvo (Bill Silvertsen) a call at Midel 02 9759 5598
Tell him your spec's and he will lead you in the rite direction :wink:
PostPosted: Thu Dec 22, 2005 10:23 pm
i might just do that Gaf, im in Adelaide but my fiancee owns her own sales company, ill put it on her bill :wink:.
