It is currently Sun Jul 20, 2025 10:44 am
PostPosted: Sun Jan 08, 2006 12:58 pm
Just emptied out my boot to clean it out, lifted up the carpet and I can see through holes to the concrete garage floor.
If i push hard enough I can flex the rust and it would easily fall through if i hit it.
Whats the plan to fix it ? New floor panel ?
Thanx in advance for any help!! :)
No more Minis!......For now.
PostPosted: Sun Jan 08, 2006 1:06 pm
depends how far gone it is..if it's just in the tire well then you can just cut it out and weld in any old flat piece of metal..
Check your battery box as well..
and also the corners below where the tail lights are..
PostPosted: Sun Jan 08, 2006 1:07 pm
Luckily its just where the tire sits. Rest of the boot is nice and strong, along with battery box.
So nothing serious I now know :) goodstuff.
PostPosted: Sun Jan 08, 2006 1:56 pm
"STOP" and "GIVE WAY" signs work a treat!!! :wink: :)
PostPosted: Sun Jan 08, 2006 1:59 pm
Pretty sure they are aluminium..
PostPosted: Sun Jan 08, 2006 2:09 pm
got similar problem in lizzie...
but mine is right at the back, you can buy a repair panel for around $60 and it goes
from one side to thbe other thats what i am going to do!.... you can actually buy
a whole boot floor repair panel so maybe you can buy one of them and just cut out the bits that you need??
PostPosted: Sun Jan 08, 2006 2:49 pm
Old computer panels work a treat..and a free..will save you $60 ;)
PostPosted: Sun Jan 08, 2006 3:48 pm
Old antique PCs are best, they were thicker... work good!
So do Hoover washer sides.... :wink: :D
PostPosted: Sun Jan 08, 2006 4:18 pm
Goodstuff.
I have a few panels lying around the place from old pc's, so im guess im right. :D
Thanx people!!
PostPosted: Sun Jan 08, 2006 6:40 pm
Max, when you are ready, I've got access to a MIG welder, and I'm sure we could teach you to MIG in about 20 mins....
Easy peasy, we'll chat about it soon, I'm sure 8)
J
PostPosted: Sun Jan 08, 2006 6:50 pm
For JAM I used a flattened out drivers door skin, cut and worked to the right profile.
For my GT I am going to spend the dosh and buy a WHOLE boot floor from Karcraft. $350 ish I believe. Yea it's expensive, but for some things you can't skimp out.
