It is currently Sun Jul 20, 2025 5:52 pm
PostPosted: Tue Jan 10, 2006 6:07 pm
Slow-Po
Does anybody else have problems filling up a mini fuel tank? I'm of the school that you stop filling after the 1st "click", however I've found that with the mini that this click is way short of filling the tank. Today I put another another 3 litres in after the click and still the fuel gauge stopped shy of the "Full" mark.
Next time I fill up I might try for another 5 litres after the first clikc, but I'm cautious of over filling. Any advice? :)
PostPosted: Tue Jan 10, 2006 6:10 pm
I usually fill quickly until the click. From then I look down into the filler while filling slowly until I can see the fuel at the bottom of the filler neck. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Jan 10, 2006 6:12 pm
i am wondering the same thing, my mini only lets me fill up bout 12 litres at a time (i don't let the gauge go into the red zone) when i check it is only 3/4 full. the service station attendant (cause some of ours are not self service :) ) says it is caue the tank is so full and if you try filling up wit hthe nosele (end of bouser or what ever) further out of the tank it dosen't work, cause of the geometry it won't fill up, it just cuts off.
PostPosted: Tue Jan 10, 2006 6:14 pm
The TIG
I find that filling it by eye is the way to go as well.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Tue Jan 10, 2006 6:16 pm
I find if I fill it too far, it just leaks out of the cap anyway...
Lillee - 1969 Morris Mini K
PostPosted: Tue Jan 10, 2006 6:17 pm
yer i leave mine till it gets to the bottom off the red
then fill to the first click then so ya dont spill any if ya aint got a good cap :oops:
i only go the full tank for long trips :wink:
PostPosted: Tue Jan 10, 2006 6:24 pm
Slow-Po
I wish I could fill be the eye method, unfortunately I need to run one of the unleaded fuel flaps (which seem redundant now that you can only buy unleaded anyway). No problems with the cap seal, I suppose that's the trade off for having the flap.
PostPosted: Tue Jan 10, 2006 6:34 pm
my theory is that Mini fuek gauge sender units are cr@p from the factory and every one reads differently.
I stop at the first click, and this will show FULL on the gauge.
Through trial and error I know that after using only 4L it drops to half....where it stays for an eternity......before rapidly dropping to empty.
At empty on the gauge it takes 20L to fill to first click :wink:
Website: www.justanothermini.com
PostPosted: Tue Jan 10, 2006 6:51 pm
same as 68 delux
fill too far and first corner.... mmmmm smell
but first click is not full about 2 literes after is my safeline
ook!
69 mini k
Users browsing this forum: No registered users and 72 guests
