It is currently Sat Jul 19, 2025 7:37 pm
PostPosted: Fri Sep 10, 2004 12:41 pm
Ok guys I am just trying to get an idea of how much it would cost to turbo a gti engine. This is the go, lets say its geting whacked into a clubman. All I want to know is how much it would cost to get everything needed to make the engine a turbo engine, an idea of what sort of parts are needed and if things like a front mount would fit. Don't want to do any body mods, and want to keep the engine stock internals etc...so how much boost could be run on a stock engine? I think that all makes some sort of sense, anyway just lend me what ever information you have. Thanks
Todd
PostPosted: Fri Sep 10, 2004 1:57 pm
what sort of GTI ? peugeot, proton, there are plenty of them ???
if it's not an A series, I suggest you go to a specialist for the car the engine came out of
PostPosted: Fri Sep 10, 2004 3:08 pm
sorry its a suzuki gti engine.
Its obvious that its not an A series but a lot or people on here do have knowledge about things other then just mini engines.
PostPosted: Fri Sep 10, 2004 4:05 pm
to turbo a g13b you will need:
Turbo: $200-$2500
Manifold: $400-$700
dump pipe: $200-$300
Oil delivery line: $40?
Oil return: $70
Water lines in and out: $100
piping from turbo to inlet $50
that will get your engine to boosted, but how long will it last standard?
You will also need an,
extra injector+ controller: $250
adjustable fuel regulator:$199
fuel pump: $199
blow of valve: $100-300
brad.
1974 Moke - 998cc
PostPosted: Fri Sep 10, 2004 4:42 pm
Thanks brad, it at least gives me some idea of the cost involved. If/when it actually happens it would only ever run low boost so it should last a while and if and when it does pack it in, makes a good excuse to rebuild the engine. Thanks again brad.
PostPosted: Fri Sep 10, 2004 9:54 pm
If ya want some more info ya could get in contact with Con Torisi, he has/had a turbo GTI clubby.
His webstie is : http://www.twincamturbo.com/
PostPosted: Tue Sep 14, 2004 11:39 am
http://www.redlinegti.com
Go there.......itll tell you want you want to know about the suzi motor.
[Maverick] 1971 Mini K
PostPosted: Thu Sep 16, 2004 12:48 pm
This could be a good start todd??
http://forum.hot4s.com.au/messageview.c ... adid=25515
Its a manifold with a t2,t25,t28,gt25 flange, some heat shield, and turbo for $400. Send him an email for some pics.
1974 Moke - 998cc
