It is currently Sun Jul 13, 2025 7:17 pm
 Post subject: Tyre Pressures
PostPosted: Mon Apr 05, 2004 6:21 pm
Ok, I just pumped up the spare tyre in my car(yep, the 1974 Original with hubcap), and realised I had no idea how much pressure to fire into it.
So in conclusion, what's the recommended tyre pressure for a mini, and what are the pressures you run in your tyres?
"He's always been a dickhead, He always is a dickhead, He will always be a dickhead. So stop complaining when he acts like one."
PostPosted: Mon Apr 05, 2004 6:33 pm
I wack 30psi in. Whether it's right, I dno.
PostPosted: Mon Apr 05, 2004 6:53 pm
i run about 36 psi in mine 165x10
GTi Turbo'd mini, abused daily
PostPosted: Mon Apr 05, 2004 7:31 pm
Cooper S (first Mini with 145-10 radials) used 28F/26R.
I run 30F/28R on the road, on the track I pump 'em up to 36F/34R. Using Yokohama 165/70-10 A008s.
PostPosted: Mon Apr 05, 2004 8:28 pm
Cheers fella's. Letting em fall to 20 definitely makes the steering sloppy. Much better above 25
PostPosted: Mon Apr 05, 2004 8:35 pm
Specially the rears. Not good having your rear end think for itself!
Users browsing this forum: slacko and 80 guests
