Ok so I need to go backwards for a minute here because after I put the swivel hubs back on and attached the tie rod and steering arm I went to put the flange in. After about 5 minutes I realised that I really should have put the flanges through the hub first because the splined drive of the drive shaft slides nicely on the flange but the outter circumfrence of the flange is where all the tightness is. Dumbass!
Anyway I've hit a snag cause I can't seem to get the drive flange to slide all the way through the wheel bearings. I'm not sure if it has something to do with the new wheel bearings I have which are different to the old ones.... the ring that contacts the flange is wider than the outter bit. Basically its flush with the out ring on one side, and sticks out a bit on the other side. At the moment I have the extra lip facing outwards and the 'collar' part in between the two bearings. I'm starting to think I shoulda not used the collar and had the lips facing inwards towards each other.
Has anybody used this type of wheel bearing? I was gonna just take the flanges out and have a closer look but they're in there pretty tight (not like when I took the old ones off), whats the easiest way to get the flanges to come out?
thanks,
dewey
P.S: Here's a little diagram to try to explain what I think is going on....
black: flange & swivel hub
red: tappered washer thingo
pink: Grease seals
blue: Wheel bearings
orange: bearings themselves
green: the spacer collar thingo
