It is currently Thu Jul 17, 2025 12:53 pm
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 26  Next
PostPosted: Tue Jan 17, 2006 5:34 pm
thomen wrote:
what would i need to change if i were thinking of subs and big sound?
Forums! 8)
PostPosted: Tue Jan 17, 2006 5:36 pm
thomen wrote:
sorry call me a total car virgin but whats an altenator whats a distributer? like i know the altenator recharges the battery's charge but distributer? what would i need to change if i were thinking of subs and big sound? and recommendations of good matches?
The distributer is the thing that makes the spark plugs spark.
For a big sound system you will need a big alternator.
PostPosted: Tue Jan 17, 2006 5:39 pm
Thank you sorry! i posted in the wrong section!
PostPosted: Wed Jan 18, 2006 2:28 pm
Hi guys. A question that DrMini or Marcel might be able to answer for me. The breaker plate is held in by 2 screws, just along side of one, is a small notch, half in the body & half on the plate. By loosening these screws & using a small flat blade screwdriver in the slot, the breaker plate can be rotated. What will be the effect of altering the position of this plate? Will it vary the maximum advance, or only alter the effect from the vacuum unit?
Thanks. Scott.
PostPosted: Sun Feb 19, 2006 6:18 pm
Thankyou so much 1st to Doc (aka kevin) for his instructions and 2nd to Hagar for his inspiration 4 me to do the conversion and the other guys who sent me pics - i should be shot for not knowing what a goddam flange is.......
Putt Putt now not only has the 1310 under the bonnet (with thanx to many other forummers) but the Pulsar dizzy went straight in - i was not sure too much about the wiring but saw an n12 with dizzy on at wreckers 2 days ago (black with white stripe wire to positive and blue to negative on coil) so hooked main wires as per that - i then hooked the little third wire (same spot as mini dizzy) upto negative on the coil - but then got NOTHING no fire, so told my little bro to disconnect the little wire and Putt Putt kicked like a stallion in Brokeback Mountain :wink: :wink: he fired just like a bought one and has not missed a beat since.
cheers all - btw to anyone thinking of doing this the 85 has about 10 times the meat to file off than the 83 does (i have an 83 ready for the 998 rebuild)
ta gerard
PostPosted: Sat Mar 25, 2006 8:57 pm
Thanks. Scott.
That is the points gap adjustment. Opening the points will advance it a bit, closing em will retard.
Normal gap is .015" when the moving points rubbing block is on top of the cam.
PostPosted: Mon Mar 27, 2006 9:19 pm
Sorry Doc I think you misunderstood. I was referring to the Pulsar dizzy I'm converting. The 'breaker' plate does rotate when you move a screwdriver in the slot, but does this effect the total advance or just fine tune the timing?
PostPosted: Mon Mar 27, 2006 9:32 pm
OK I know what you mean now.
I just lined those marks up when I put one back together. I think it may vary the relationship between the rotor and the cable lugs in the cap, ie where the spark jumps from on the rotor.
But, I could be wrong...
PostPosted: Mon Jun 05, 2006 3:31 pm
i am interested in installing a pulsar dizzy into my mini . my current mini dizzy has a crack in the cap and a bent drive dog, My ignition coil is off a pajero? ? for some reason
i dont wanto put $16 for the cap and $? for the drive dog when i shuld just go to the pulsar like i have wanted to for ages....
if anyone has a already modded dizzy (and coil maybe) that they are willing to sell please pm me and name your price
cheers!
PostPosted: Mon Jun 05, 2006 3:55 pm
is for an 1100 clubman.... sorry..
PostPosted: Wed Jun 07, 2006 4:54 am
got a new rebuilt dizzy but no wiring came with it..which terminal is the Black/White wire on? or which is positive and which is negative?
PostPosted: Wed Jun 07, 2006 7:00 am
Blue wire is to - terminal. :wink:
PostPosted: Wed Jun 07, 2006 7:38 am
thank you doc but inside the dizzy which one does it connect to or does it really matter? There is no markings on the module. and I really do not want to let the smoke out.
PostPosted: Wed Jun 07, 2006 11:08 pm
bit dark out there now, I'll check which in the morning... :wink:
<edit> I just saw you found the answer on MM forum, but will check mine too.
PostPosted: Thu Jun 08, 2006 5:22 am
Thank you Doc I did. I like to ask on as many forum's as possible, you never know who is awake. just have to go to the store to get some terminal ends. I don't have the right size on hand.
