It is currently Sat Jul 19, 2025 7:30 pm
 Post subject: Water pump question
PostPosted: Tue Sep 14, 2004 3:40 pm
Are water pumps overhaulable? - Aluminium housing has "growths" inside from the water - the cast iron impeller is rusted - bearing unknown. I have two in such condition and a third on the car internals unknown. Don't particularly want to buy one for the sake of buying it but thought if one can be made 'nearly' new then why not :wink:
David L
PostPosted: Tue Sep 14, 2004 4:12 pm
Dude,
Just ditch it. They not expensive. If you are doing a concourse resto the original steel ones can be rebuilt but works out more money than buying a new alloy repro.
1962 Mini Speed sports sedan
PostPosted: Tue Sep 14, 2004 7:10 pm
I agree. If buying an alloy one, particularly for a 1275, avoid the ones with the tin impellers- they don't pump as well as the cast ones.
If you really want a cast iron original pump I've got one you can have for nix, but the kits are dearer than a new alloy pump! :x
PostPosted: Tue Sep 14, 2004 7:18 pm
Thanks for the offer Kevin - but I'll get a new alloy one when I get round to fitting the new head.
David L
