It is currently Sun Jul 20, 2025 6:13 pm
PostPosted: Sat Feb 04, 2006 11:53 am
hi all!
that means they arent working! Heyy guys for those who dont know me cause i have never posted before i bought chezel from Zerial, and chezel's break lights arent funtioning! The parkers work and the blinkers but no break lights...
please help!
a girlfriend would be cheaper
PostPosted: Sat Feb 04, 2006 12:57 pm
Check the brake light switch which is a fluid pressure switch mounted on the drivers side rear of the front subframe (follow the brake line down from the master cylinder to the subframe and you'll see a junction block , the switch should be on top of it) , it's possible the connecter could have come off , also check the bulbs themselves though it seems unlikely for both of them to have stopped working . If bulbs and switch is connected then time to check the switch is working with a multi-meter while someone pushes the brake pedal on and off . Hope this helps , should be something simple like a connector loose or off .
PostPosted: Sun Feb 05, 2006 11:45 am
will do, thanks heaps
PostPosted: Sun Feb 05, 2006 11:58 am
Also check the connection and clean them up (this happened to me)...bugger If I had of known you had problems I would have stoped in I was just up the road at the doctors and waited four hours for a perscription..you may have heard me leave.
Yes I know where you live..my mum tels me what your up to hehehehe
PostPosted: Sun Feb 05, 2006 1:50 pm
lol.. are u serious that would have been heaps good!
would i know who you are? or is it just cause chezel used sit out the front?
PostPosted: Sun Feb 05, 2006 2:58 pm
nope..Cheziel sits out the front and my mum live's down the road from you :wink:
PostPosted: Sun Feb 05, 2006 3:24 pm
kool kool
i found that where the wires connect to eh switch, that one of the pongs have snapped off, any ideas on how to remove it?
PostPosted: Sun Feb 05, 2006 3:48 pm
from the switch..you have to buy a new one :?
PostPosted: Mon Feb 06, 2006 10:11 pm
ive removed the part with the longest-ass socket arm ive seen to date
thanks for the help, hopefully i can now attend a mini cruize before chezel has a date witht he spray booth
Users browsing this forum: No registered users and 70 guests
