It is currently Sun Jul 20, 2025 2:43 pm
PostPosted: Sun Feb 05, 2006 9:51 pm
Has anybody got retractables in their roundnose?
Do they get in the way of access to the backseat?
Mini K, 1310, Jet Red/Crystal White Roof, Rover Interior
75 Clubman
PostPosted: Sun Feb 05, 2006 10:18 pm
Yes, and No, but I've got a Rover.
2008 Prado GXL
PostPosted: Sun Feb 05, 2006 10:19 pm
I have them in my '61, the reel and bottom mount go into the same large screw in the bottom by the door sill.
Access isn't restricted at all.
PostPosted: Sun Feb 05, 2006 10:23 pm
This is aquestion - not a criticism
I had heard that retractables in an early mini leaves the "b" pilar likely to collapse in a big hit.
I would be interested in an engineers opinion on this
PostPosted: Sun Feb 05, 2006 10:24 pm
In a big hit, all pillars are likely to collapse! :lol:
PostPosted: Mon Feb 06, 2006 5:48 am
How would retractables make this any more likely than regular seatbelts?
if you want safety, dont drive a mini :)
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
PostPosted: Mon Feb 06, 2006 7:02 am
With a static belt there is a direct 1:1 pull against the top mount in a frontal accident.
With a retractable, the belt locks in the reel at the bottom, and then the load on the top mount is doubled as the belt sliding anchor acts as a pulley `snatch block'. :cry:
From about 1968 on the B pillar was made stronger and is effectively same as a Clubby one (which had retractables), so should stand this load OK.
Earlier cars, I'm not sure how well they would cope with retractables- but they are probably safer for you than loose fitting static belts.
I run retractables in our 1970 Matic and they are great.
I had them in our 67 Pretend S, but took them out as they fouled the (early Clubby) seats fitted. :cry: Bah I hate static belts.... :x
PostPosted: Mon Feb 06, 2006 8:54 am
I know in NSW for a long time with older cars if you wanted to fit retractable belts RTA did require an engineers report on the mounting points because of what doc said about the change of loads, I think it is still pretty much the same for early cars to be legal
Jon
PostPosted: Mon Feb 06, 2006 10:03 am
Jon
Well, the Klippan website listed the K1214? retractable belt for ALL Minis last time I looked.
PostPosted: Mon Feb 06, 2006 10:24 am
I've looked into this for my 1960 roundnose and the thing with retractables is it can be done, but there's no provisional drilling holes under the body for the belts given they weren't factory fitted.
I believe you'll need to get the retractable thing engineered as where it's bolted on has to be strengthened with a plate.
For the hassle I found the best route to go was non retractables, which i'll be getting done sometime in the next few months.
Shard
PostPosted: Mon Feb 06, 2006 11:24 am
My 68 Mini Matic still has the old style seat belts up front with the lap style one's in the back.
PostPosted: Mon Feb 06, 2006 2:35 pm
Minis didn't get rear belts standard until Jan 1971 I think.
My 3/1970 Mini Matic had standard static lap/sash belts in front but there are no rear seat belt mounting points, even for lap belts.
PostPosted: Mon Feb 06, 2006 2:49 pm
just pull the **** tight... ;)
PostPosted: Mon Feb 06, 2006 2:54 pm
^ or just "fill out" until the seatbelt gets tight :lol:
PostPosted: Mon Feb 06, 2006 3:35 pm
So retractables in a mini K should be safe?
However once fitted clubman seats are no longer an option!? (not sure if that is a statement or a question)
75 Clubman
Users browsing this forum: Bing [Bot] and 80 guests
