It is currently Mon Jul 21, 2025 12:18 am
 Post subject: Fixing rust holes?
PostPosted: Mon Feb 06, 2006 6:23 pm
There are a couple of rust spots in the top front corner of my front guard.
They are only small but they go right through. Is there a good alternative to welding them up as I only have an Arc welder and I'm presuming you need a mig?
Fortunately this is the only rust in the car I think the front may have had a minor altercation at some stage.
PostPosted: Mon Feb 06, 2006 6:39 pm
Unless you cut it out and weld it I guarantee it will be back, eventually.
Ask around on here, some Mini nut near you will have a MIG...:)
Edit.. if you do decide to fibreglass it, cut ALL the rust away until you get back to clean metal. But this is really no substitute for welding a patch in.
PostPosted: Mon Feb 06, 2006 7:36 pm
Ok, welding it is.
Thanks again Doc
PostPosted: Tue Feb 07, 2006 6:14 am
What about those newer 'as good as steel' fillers? You probably wouldn't do it for a concours restoration, but for a small, non-structural hole, I think it's ideal. And the price is right. As above, clearing out all the rust is the key.
Users browsing this forum: Majestic-12 [Bot] and 90 guests
