Edge wrote:
Leave it at least 2 months before even washing it - and then some.
It takes around 9 months for it to harden properly!!
But you should be right after 3 months.
I wouldn't touch it with wet/dry, even 1200.
Do it by hand,
DON'T use a machine, and use silicon free cutting compound.
You can get different grades of compound too - best not to get one too vicious.
Take it real easy too - circular motion, not too much pressure, and wipe it off when the compound has worked into the rag to check how yr going. You can go too far without realizing it otherwise.
Best to leave slight dimples (for want of a better word) than go completely smooth unless you've put on more than 4 good coats. Leaves a bit then for future polishing.
Have a look at paint on a new VW Golf - you'll see what I mean.
firstly when i am saying what i am saying, i would not contemplate putting on only 4 coats of paint.. that is too few.
And why not touch it with 1200/1500? if this is a first time spray at home, then ill give the bloke a gold medal if he gets the final few coats flat off the gun with no crap or runs in there. There is nothing wrong with 1200/1500 if it is used correctly. there is no need to wait 9months to rub it back with 1200 or buff it either.
And you pretty much have to use a machine. the whole idea of a buff is to get the maximum shine out of your paint. When you buff by hand, you cant build up the required heat needed to effectively "move" the paint to flatten it out and give it a shine. If it gets a buff by hand it will just coe out llookin very mediocre.
