It is currently Sat Aug 02, 2025 10:02 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Feb 08, 2006 8:46 am
Not quite watto
willy's is a 1300 auto it has the same body and everything else as a 1500 but uses the 1275 engine and an auto gearbox :wink:
I always thought the landcrab was a 1800 :D
Apparently not all of the 1500s were 5 speed either some had 4 speeds.
http://www.elevenhundred.com/morris1500/index.php for more info :wink:
Roads need more corners
PostPosted: Wed Feb 08, 2006 9:10 am
Here's what you wrote...
watto wrote:
1300..?!
Landcrab..?!
Err, guys, the pics are of a Morris 1500.
They are nice pics too, but I should point out that the 1300 uses the 1275 (1100S motor in Australia) A Series engine, whereas the 1500 has a 1500cc overhead cam engine (I don't know the series type.) and five-speed gearbox with cable operated gear-change.
The Land Crab, as it is affectionately known, is the Austin 1800, which uses a B Series engine - like the MGB (for the Mk2 anyway).
The front grille is quite different on the 1500, whereas the 1300 and 1100 are very similar - and IMHO much better looking. Easiest way to tell the 1100 and 1300 apart is the taillights - 1300s are flat. Also, as stated, in Australia it would be an 1100 S, not a 1300.
So, the 1100 and 1100 S are both closely related to the Mini, kind of a big Mini with 4 doors (a Biggi perhaps?), whereas the 1500 and 1800 are quite far removed from the Mini/1100 concept, despite the initial similarity in appearances.
Here endeth the lesson.
Cheers, Watto.
:shock:
here's what I read
Cheers, Watto.
Thanks!
PostPosted: Wed Feb 08, 2006 10:38 am
Ah, there you go.....you learn somthing new every day.
So, it is a 1300 in a 1500 body shell. Is the engine still the same trusty old 1275cc A Series?
Certainly not a Land Crab though!
Cheers, Watto.
:shock:
PostPosted: Wed Feb 08, 2006 10:59 am
Yep AFAIK, except for it is an auto block
PostPosted: Wed Feb 08, 2006 11:05 am
Velly intellesting!
That website certtainly has stacks of good info.
Cheers, Watto. :shock:
PostPosted: Wed Feb 08, 2006 12:55 pm
My appologies, but with a bit of speed it would have similar handling as the crab.
PostPosted: Wed Feb 08, 2006 2:46 pm
Is the Morris 1500 engine interchangable with the Mini?
PostPosted: Wed Feb 08, 2006 2:59 pm
just like mr gormly, it's a bit of an achor...
sorry.. i think my "w" key got stuck...
PostPosted: Wed Feb 08, 2006 4:10 pm
From the above website:
and the manual transmission models would be powered by the new 1.5 litre OHC E-series engine and cable gearbox developed for the British Austin Maxi.
So I take it the E series is a redesigned engine and quite different to the A Series.
Another quote:
The end of the road. A stock pile of 2,100 cars is left to clear pending the arrival of the new Morris Marina, which will inherit the E-series engine.
So the E series was I think originally designed for the Marina and the 1300 and 1500 were stop gaps to hold Morris sales up until the Marina came into being.
PostPosted: Wed Feb 08, 2006 4:29 pm
The E-series engine was developed for the Austin Maxi.
Leyland Australia thought it would be a good engine for Australia and took it and developed it. It was made in four different sizes. 1500 and 1750 four cylinders and 2250 and 2623 6 cylinders.
In Australia the E-series was fitted to the Morris 1500, Austin Kimberley/Tasman, Morris Marina and the P76.
You would not bother fitting a 1500 to a mini as it is a big heavy tall engine. (you might fit a 1750 though!) 8)
PostPosted: Wed Feb 08, 2006 9:23 pm
Its a Morris 1300, guys.
Morris 1300 automatic engine, and body.
PostPosted: Wed Feb 08, 2006 9:57 pm
Anyone ever Fitted a 1750 to a Mini Or is it just to fat for the engine bay?
PostPosted: Wed Feb 08, 2006 10:20 pm
I know two people who have fitted the 1500 with cable operated five-speed to Mokes, so I guess it is do-able.
Cheers, Watto :shock:
PostPosted: Thu Feb 09, 2006 6:53 pm
a while ago ( like 2 or 3 yrs) there was a mini subframe modded for a 1500 e series engine for sale on mini car club site. also a side note there is a 6 cyl e series cross sectioned at goulburn tafe in the light auto section if you ever get the chance to have a look .
lookin for another clubby
PostPosted: Thu Feb 09, 2006 7:09 pm
ausminis4u wrote:
... also a side note there is a 6 cyl e series cross sectioned at goulburn tafe in the light auto section if you ever get the chance to have a look .
Cool. I will have to walk across the road one day with my camera!
