It is currently Thu Jul 17, 2025 5:03 am
 Post subject: Arc or mig welder?
PostPosted: Sun Feb 19, 2006 3:24 pm
Which one is better for general purpose mini repairs, house jobs etc. I have got an arc welder for my b'day and have been told that I can trade up to a mig if that is what I want.
What one is better for general purpose use? Can I use the arc/stick welder on thinner steel? e.g 25mm box section and steel sheeting?
Help asap because I want to get out and weld stuff today!!! hehehe
Andy.
PostPosted: Sun Feb 19, 2006 3:35 pm
MIG is the go. I have both, but the arc only gets used for stuff 3mm or thicker now. :wink:
Yes you can use arc on RHS tube 2mm wall and up, but it's hard work compared with MIG.
and it's not great on sheet... even 1.5mm. Forget it for thin stuff, like body panels.
PostPosted: Sun Feb 19, 2006 3:45 pm
Thanks. That was the info I was looking for.
PostPosted: Sun Feb 19, 2006 6:03 pm
Some great wisdom in these threads:
http://www.ausmini.com/forums/viewtopic.php?t=7404
http://www.ausmini.com/forums/viewtopic.php?t=9811
Things I agree with most:
1) get a gas MIG with continuously variable (stepless) voltage & wire speed
2) buy an upmarket welder second hand instead of a cheap welder new
a) much easier to get replacement parts for; which means:
b) it will last a lifetime, so don't skimp
c) the quality of the result will be much better
PostPosted: Sun Feb 19, 2006 6:21 pm
All the ones with stepless V control have input voltage compensation by design, the majority of switched ones don't. This means their output voltage can vary a bit depending on the mains voltage.
You do get what you pay for. Most of the real cheap ones are toys.
Mine is a S/H Kemppi `Super Kempomat' I bought for $450 at a dealer, about 10 years ago. A panelbeater traded it. Has continuously variable voltage. It also has handy features like `spot' and `stitch' welding timers, which the cheapies just don't have.
Very useful for welding upside down, under car.:)
PostPosted: Mon Feb 20, 2006 9:48 am
I am not in the market for an expensive welder. I have decided to keep my arc which was a present to practice my skills. I have never welded before and think that the $120 birthday jobbie is a good place to start.
I had a hit on some steel yesterday and find in a lot harder than expected. Getting the arc up in the first place is a matter of luck and maintaining it required a steady hand and skill. I was able to manage a bit of a weld but nothing like my (potential) father in laws work.
PostPosted: Mon Feb 20, 2006 9:53 am
Wait until you try welding galvanised steel Bromley, that will try you out... :?
PostPosted: Mon Feb 20, 2006 10:00 am
The dodgy instruction booklet with my welder told me not to weld gal because it lets of a toxic fume! Then again the manufacturers also thought it necessary to remind me that the unit will not work unless it is plugged in and switched on, dehrrrr :lol:
PostPosted: Mon Feb 20, 2006 10:14 am
I have noticed that over the years with other electrical stuff as well.... :roll:
Users browsing this forum: Bing [Bot] and 83 guests
