It is currently Sat Jul 19, 2025 9:01 pm
PostPosted: Thu Sep 23, 2004 7:55 pm
Sounds too lean- what carb has it got? Maybe the needle is wrong now for a 1098.. :wink:
PostPosted: Thu Sep 23, 2004 8:00 pm
its a small carb 1 1/4, smaller than the matic (1 1/2)
i think it was using the same needle it came with it
and also the 3rd n 4th sparks were black,
1 n 2 were rather clean
Inconspicuously Conspicuous
PostPosted: Thu Sep 23, 2004 8:07 pm
Just to throw in some more suggestions, if the car dies when you release throttle and then starts again, idle is too high, perhaps the dashpot is sticking? Just a thought it is a common SU problem and it's caught me out before. Or the dashpot is taking too long to return, though that would be noticable on gear changes.
Just a thought.
Anto.
PostPosted: Thu Sep 23, 2004 8:09 pm
thanks anto ill check them all out
btw anto love your interior with the mini minis chasing each other
PostPosted: Thu Sep 23, 2004 8:12 pm
Thanks! I've also got a mini on the parcel shelf sprayed the same colour as my car, but the roof melted in the sun so now the model looks like its been rolled :lol:
PostPosted: Thu Sep 23, 2004 8:21 pm
hehe shoulda had a roll cage
your mother coulda toldya that
PostPosted: Fri Sep 24, 2004 6:04 pm
well the engine's doing ok now
the friend said that it could go anywhere so im happy about that
2 problems:
1. when you rev it up hard white smoke comes out (but when i drive normally, its ok)
2. speedo at the meter end does not turn
can i get anyone to help fix it on the weekend?
i am told because its not turning up here, ive gotta change the square head down there...
PostPosted: Fri Sep 24, 2004 6:20 pm
Are you meaning the little Arrow/Arm does not move. If so first thing I would look at would be the speedo cable.
PostPosted: Fri Sep 24, 2004 6:23 pm
sorry the square point of the speedo cable
its unplugged and hanging out there in front of the windscreen
it does not turn
ill read up on another thread about speedo cables
just read it, ill try everything there thanks
PostPosted: Fri Sep 24, 2004 6:37 pm
Pull the inner cable out.....If its broken you will only get half which is good becouse you know you'll have to change it and that was the problem
PostPosted: Fri Sep 24, 2004 6:41 pm
:wink: thanks mate
can i rub your head for good luck when i see you n marcia
hah sorry that came outta no where
PostPosted: Fri Sep 24, 2004 6:43 pm
Sorry I only let the ladies do that. :shock:
PostPosted: Fri Sep 24, 2004 6:47 pm
hahaha
i guess the next question is out
"hey gaf wanna shoot tequila?"
PostPosted: Fri Sep 24, 2004 6:50 pm
Yes Please 8)
PostPosted: Fri Sep 24, 2004 6:54 pm
tsss tsss tsss
is the salt falling down into your eyes? sorry
