It is currently Mon Jul 14, 2025 11:08 pm
 Post subject: Priming an Engine
PostPosted: Mon Feb 27, 2006 12:19 am
hey dooleys
can you use normal primer on an engine for engine temperatures
what about etch primer?
Inconspicuously Conspicuous
PostPosted: Mon Feb 27, 2006 12:36 am
i wouldnt bother. just use k&h range of engine enamels. i used rocket red, which really looks like fords blood orange engine enamel, good to 300 degrees, also i used k&h 'magnesium' for my extracters, heatproof to 650 degrees, good crap. you need to give the motor or whatever it is a good 6 coats or so, which u can get outta a whole can/pressure pack.
Image Image
PostPosted: Mon Feb 27, 2006 6:45 am
Engines don't get real hot, 100C max.
What he said ^^^
but get all the old paint off, and then wipe good with Prepsol.
PostPosted: Mon Feb 27, 2006 7:04 am
I use normal etch primer, and normal cheap spray can paint from Mitre 10... I've never had engine paint come off...
it's all in getting the block really clean before priming
so NOT what they said ^^^ :lol:
PostPosted: Mon Feb 27, 2006 7:35 am
They are both right ^^^. If the paint comes off, the block was dirty. :lol:
PostPosted: Mon Feb 27, 2006 9:08 am
thanks ill give it a good wipe down
PostPosted: Mon Feb 27, 2006 12:18 pm
what's Prepsol please :?:
PostPosted: Mon Feb 27, 2006 12:25 pm
Grease and polish remover, get it from places like VG Paints.
PostPosted: Mon Feb 27, 2006 12:43 pm
Thanks. Would I use it to remove old body polish before re-waxing again :?:
I suppose it's not abrasive say, like T-Cut, the "sol" bit as in solvent ?
Sorry about the quiz but it sounds just right to apply before trying to repair some stone chips etc :)
PostPosted: Mon Feb 27, 2006 12:47 pm
I did my engine in White Knight Hammertone - it looks magic.
You can buy from bunnings - like everyone said just make sure it's clean and grease free and you whould have no problems 8)
Bob Slattery
PostPosted: Mon Feb 27, 2006 1:45 pm
Duc I'll drop you over some primer if you like.
what colour are you painting the engine?
steve
PostPosted: Mon Feb 27, 2006 2:10 pm
Twista's Broboymini is brought to you by K&H Surface Technologies, EST 1961.
:D
PostPosted: Mon Feb 27, 2006 4:33 pm
:D
ohhh righttt - giggety giggetty
oh harley, its BADBOYMINI
Image Image
PostPosted: Mon Feb 27, 2006 4:36 pm
prepsol is a solvent, to get rid of grease and any other crap thats on there. so its fine in most cases, i worked in a paint studio, and we used it before we applied any vinyl etc to make sure the surface was clean.
Image Image
PostPosted: Mon Feb 27, 2006 7:08 pm
PREParation SOLvent = prepsol
sounds plausible to me...
