It is currently Mon Jul 07, 2025 7:05 am
PostPosted: Mon Feb 27, 2006 2:51 pm
heyas i have removed the cv joint and replaced the boots but am having trouble gettin the cv back in - the circlip is stopping it. the haynes manual says get a tool number blah blah but is there a handy way to pop it back on?
PostPosted: Mon Feb 27, 2006 2:55 pm
Give it a sharp tap against a piece of wood or something that won't hurt it..
so you will have to hold both the drive shaft and the cv and bang it ona bit of wood. Bang it down on the CV joint end not the pot joint / uni joint end
make sense :?: :)
Roads need more corners
Last edited by fuzzy-hair-man on Mon Feb 27, 2006 2:57 pm, edited 1 time in total.
PostPosted: Mon Feb 27, 2006 2:56 pm
NAV-MAN
you need to compress the circlip a bit and tap it on with a hammer.
Well it worked for me anyway
 Post subject: cable tie
PostPosted: Mon Feb 27, 2006 5:18 pm
Have I read somewhere where you slip a cable tie over the circlip then drift the joint on??? the cable tie slides down the splines and can then be removed??
Sounds like good bulldust to me :!: :!:
PostPosted: Mon Feb 27, 2006 5:24 pm
I was going to say I've always found a good sharp tap with a block of wood helps until I read Mick's idea above , that sounds brilliant and should work a treat . :D
PostPosted: Mon Feb 27, 2006 6:16 pm
hmm i dont think it was the circlip at all, i think it was the spring ring on the end of the shaft. i just made a new one and fed that into the groove and she stuck in...i guess ill see what happens on the other side
PostPosted: Mon Feb 27, 2006 6:26 pm
Yeah , spring ring , that sucker , but I can never think of that either so I call it a circlip as well .....
