It is currently Sat Jul 19, 2025 8:58 pm
 Post subject: What role ?
PostPosted: Sat Sep 25, 2004 1:27 pm
What role/effect do different thickness spacers make in the carb to manifold setup?
I have 2 standard at .35 " one at .5" and one at .25" What is recommended for a twin SU setup?
David L
PostPosted: Sat Sep 25, 2004 2:57 pm
On a single SU manifold, the thicker the spacer is the better- it puts a bit of volume between the butterfly and the manifold wall.
On twins, it doesn't matter so much- the thinner ones should be OK if the linkage all clears everything. :wink:
