It is currently Sun Jul 20, 2025 8:46 am
 Post subject: ignition lock
PostPosted: Mon Sep 27, 2004 10:27 am
How do you know when your ignition lock is buggered? Mine has just decided to not turn anymore. The steering lock is on and no matter how much i fiddle turning the wheel and key it doesn't budge. The key won't even turn. Its basically like its the wrong key, but it is the right key. How do u take the ignition thing off the steering column anyway? or do you have to replace the ignition and steering column together?
ash
PostPosted: Mon Sep 27, 2004 11:30 am
Clubby??
Your barrel might have packed it in. Maybe one of the springs on a pin has broken. There are 4 bolts holding the ignition barrel to the column. You can unscrew them with a flat blade screwdirver and remove the whole ignition barrel. Column stays put.
Plenty of second hand ones around with key. Attach in reverse order to removal.
Anton.
PostPosted: Mon Sep 27, 2004 1:05 pm
flat blade screwdriver? mine doesn't seem to have anything to put a screwdriver in. its completely flat. or should i somehow grind some slots into them? Its a clubby.
PostPosted: Mon Sep 27, 2004 1:09 pm
I agree when I replaced Morris steercolumn I had to drill out the "bolts" as thier was no way to unbolt them. Was not to much trouble thought
PostPosted: Mon Sep 27, 2004 1:36 pm
mine has flat blade countersunk heads. Might be a late clubby thing or mine was modified before i bought it. I thought they were all like that. :?
PostPosted: Mon Sep 27, 2004 3:48 pm
The bolts are 'shear-head' type. In other words, when you do them up, the heads shear off so no bugger can remove your steering lock and nick your car! Well done Leyland! Drill them out or use a stud remover and get some new ones. Karcraft should stock them.
PostPosted: Mon Sep 27, 2004 8:08 pm
heaps of people do this ;) only thing is crims can undo the screws and hor wire ya mini without damaging the colum then :(
lookin for another clubby
Users browsing this forum: Bing [Bot] and 80 guests
