It is currently Sun Jul 20, 2025 8:39 am
 Post subject: Clutch noise
PostPosted: Tue Sep 28, 2004 6:44 am
Hi all
My clutch has started making a squeaking noise when depressed, sounds like there are a flock of sparrows under the bonnet.
I am guessing it is something bad, anybody had anything similar?
Stu
PostPosted: Tue Sep 28, 2004 6:53 am
Clutch release bearing.
Can be fixed in the car. Use a good UK-made bearing (RHP)- the cheap jap bearings are a POS (3 weeks, I got from the last one I used) :cry:
PostPosted: Tue Sep 28, 2004 7:17 am
RHP :?: DOc
PostPosted: Tue Sep 28, 2004 7:43 am
gafmo wrote:
RHP :?: DOc
RHP = RansomeHoffmanPollard- UK bearing maker.
Their bearings can be got from any bearing supply house, they also come in the Borg & Beck (and probably Unipart) clutch kits. :wink:
If release bearing doesn't have `made in England' on it I won't buy it any more.
PostPosted: Tue Sep 28, 2004 4:48 pm
i'm glad.... i'm about to get the borg and beck kit :)
PostPosted: Tue Sep 28, 2004 6:23 pm
yeah mine just started maiing that noise the other day....wondered what it was
maybe we should have a clutch-bearing-fix-it-up day cush :lol: :roll:
play 3d car games for free
PostPosted: Tue Sep 28, 2004 6:25 pm
i was just going to send mine to the pros :)
PostPosted: Tue Sep 28, 2004 10:00 pm
fair enuf i spose.... :? where's the satisfaction in doing that though?? knowing you;ve done the job yourself!
speaking of doing the job yourself.....is it a hard job for a novice (like myself) to do? or does cush have the right idea in sending it to the pros?
PostPosted: Tue Sep 28, 2004 10:09 pm
Release bearing job is real easy, once you get all the bolts out of the clutch cover. Bottom 2 are tricky. I use a 1/2" ring/OE spanner with the ring end heated and bent to 45*.
Works for me... :wink:
PostPosted: Tue Sep 28, 2004 10:13 pm
and its in the black book?
how long do they usually last? cos i had a new clutch etc put in about a year and a half ago..... :?: :?
PostPosted: Tue Sep 28, 2004 10:28 pm
Would be in the book- just stop `clutch dismantling' once you have the cover off. :lol:
How long is a piece of string- it should last for years if you don't ride the clutch at the lights or rest your foot on it... :wink:
Maybe you've got one of the cheapo jap bearings in there...!
PostPosted: Wed Sep 29, 2004 10:02 am
i was giving it to the pros beacause i'm not enritrely sure what the problem is and it's a case of.. "while you're in there...." :)
plus, i get the satisfaction of not arsing it up
PostPosted: Wed Sep 29, 2004 10:57 am
well i havent been riding the clutch or resting my foot on it.......but my engine mounts are on the way out so i've been VERY gentle on gearchanges for a few months now.....
ahh well, i'm guessing just doing the bearing isnt too expensive either is it?
PostPosted: Wed Sep 29, 2004 11:00 am
the part is bugger, if i remember, so it's all labour...
PostPosted: Wed Sep 29, 2004 11:09 am
You heated your spanner?? I bought a $1 Super Cheap spanner, just bent it in a vice :) They do have a habit of snapping though.
The annoying part is that I have lost my custom spanner for clutch end covers, and I'm up for a bearing replacement again!
Users browsing this forum: No registered users and 69 guests
