It is currently Sun Jul 20, 2025 12:51 am
PostPosted: Wed Sep 29, 2004 3:29 pm
thommo09 wrote:
... but my engine mounts are on the way out so i've been VERY gentle on gearchanges for a few months now.....
What are the signs of an engine mount going? I thought the engine mounts lasted for ages.
PostPosted: Wed Sep 29, 2004 4:17 pm
Generally it starts with excess engine movement, which usually starts with the engine steady bar bushes wearing out. My engine moves a huge amount at the moment, because the bracket on the bulkhead where the steady bar attaches has broken off and needs welding. I have noticed, as well as the 'thump' on throttle application, sometimes I hear a loud crack (like I ran over something) when I'm working the clutch. Not a good thing, I think I'll fix it this weekend!
I've heard also that clutch judder can sometimes be caused by bad engine mounts.
Anto.
PostPosted: Wed Sep 29, 2004 5:38 pm
Anto wrote:
Release bearing job is real easy, once you get all the bolts out of the clutch cover. Bottom 2 are tricky. I use a 1/2" ring/OE spanner with the ring end heated and bent to 45*.
Works for me... :wink:
You heated your spanner?? I bought a $1 Super Cheap spanner, just bent it in a vice :) They do have a habit of snapping though.
The annoying part is that I have lost my custom spanner for clutch end covers, and I'm up for a bearing replacement again!
It was a cheapo (Indian) spanner but had the magic words `chrome vanadium' on it. They are tough stuff, but warm it up in the vice with the oxy and it bends OK, easy peasy. :wink:
PostPosted: Thu Sep 30, 2004 1:43 pm
Ah I see. The ones I used weren't chrome vanadium coz they are the el cheapo ones. I've lost count of how many I've snapped trying to loosen tight bolts etc - hence why I bought a more expensive set!
PostPosted: Fri Oct 01, 2004 5:58 am
Thanks for that DrMini, I will have a look at it this weekend.
I was worried that the whole engine might have to come out.
Stu
PostPosted: Fri Oct 01, 2004 6:48 am
Also, I tack weld the 2 nuts into the engine mounts and then fit the bolts & spring washers from outside. Line 'em up with a #2 philips screwdriver in the holes. :wink:
Yeah- I know you CAN buy mounts with `captive nuts', but these mounts are too thick to fit in easily. I bought one last time- never again. :cry:
