It is currently Sun Jul 20, 2025 8:39 am
 Post subject: Last Check
PostPosted: Thu Sep 30, 2004 4:28 pm
Picked up my brake master cylinder back from full rebuild so i just want to go through this bleeding thing
Connect the master cylinder back up to pipes and pedal
Fill with Brake Fluid
Jack up the righ hand side of the car and attach plastic pipe to the bleed screws on the back and front wheels RH first unscrew the bleed screw put the other end of the tube into a glass jar with brake fluid in
get friend to push the pedal full strokes untill no more air bubbles can be seen
keep fluid full half way
push pedal all the way to the floor then do up screws then next side
Right or wrong
Its a dual circuit brake master cylinder
PostPosted: Thu Sep 30, 2004 5:03 pm
High heel ninja
Put the car back together take it too your local brake specialist, get them to bleed it, the best $20-$30 you will ever spend, no aggression, no lying on the floor, no spilled brake fluid.
Doogie
PostPosted: Thu Sep 30, 2004 7:00 pm
after what i ended up paying for the rebuild :shock: i am a little put off taking it to a brake specialist well at least the one i got it done by
soo if i can do it i want to give it a go kinda a thing i wouldnt mind learning you know
BUT if i fail i will take it to one
PostPosted: Thu Sep 30, 2004 7:28 pm
i find the best way is:
no need to jack car up
do all nipples up
fill reservoir with fluid
get someone to continually pump the pedal, about once every second
you get under car
open one nipple slightly
watch it spurt out and get the timing
close at half the spurt
turn wheels max to get to front nipples
do up with little spanner
very messy put rag under and dont wear long sleaves/watch
remember to adjust the brakes after, non adjusted brakes wont eat and you'll blame the nipple bleeding
Inconspicuously Conspicuous
PostPosted: Thu Sep 30, 2004 7:42 pm
wont need to adjust them they are newly adjusted
so the way i described will/wont work
PostPosted: Thu Sep 30, 2004 7:44 pm
it looks like your way will be definitely much cleaner than the one ive described
you can even do that yourself as well
i say it will work.
PostPosted: Thu Sep 30, 2004 7:55 pm
thanks i hope so well i quess i will know by tommrow lolt
it says in the haynes manual that for a dual circuit to do front and rear rh side first so two together then the other two hope this is righht
 Post subject: Austin Powered!!
PostPosted: Thu Sep 30, 2004 8:48 pm
68matic wrote:
i find the best way is: you get under car
I just knew Mini Mi would have to be a Mini owner!!! :wink: :lol: :lol:
