It is currently Sat Jul 19, 2025 9:35 pm
PostPosted: Mon Mar 20, 2006 8:45 pm
Hi all I am wondering if somone can help
before I took out the triple gauges out of my car (actually I think it was before I took out the 998 and put in the 1275) the Tachometer worked .... Now since I have had had the gauges out I have a green wire that disappears into the abyss of harness - can anyone tell me where this wire would go to I want to get the gauges working before I put in the new dash.
Jack Read said that there should be a white wire that splits to plug into the tacho - (which I have found a white loop) but when I open that loop the car will not start .....
Anyone got any ideas???
Cheers Gerard
PostPosted: Mon Mar 20, 2006 8:47 pm
Green wire on my aftermarket tacho went to the coil if thats any help ?
No more Minis!......For now.
PostPosted: Mon Mar 20, 2006 8:48 pm
resident alien
resident alien
Other than the main wire plug the only other cable should be a white with black stripe that connects to the tacho.
PostPosted: Mon Mar 20, 2006 8:49 pm
Ta - I thought that was where it went too a few green wires under the bonnet
(I changed the coil in the upgrade to a pulsar dizzy - any ideas whether positive or negative???)
cheers Gerard
PostPosted: Mon Mar 20, 2006 8:52 pm
Mine went to Negative
PostPosted: Mon Mar 20, 2006 8:54 pm
resident alien
resident alien
White/black strip wire goes to -ve coil
PostPosted: Mon Mar 20, 2006 8:56 pm
green- to neg of coil
red- to power/fuses
white- lights
black- earth/ body of car
i think thats it isnt it :P
Yup, Thats it.
PostPosted: Mon Mar 20, 2006 8:57 pm
thanks guys
PostPosted: Mon Mar 20, 2006 9:03 pm
easy as....... :wink:
PostPosted: Mon Mar 20, 2006 10:19 pm
Just put a post up about this
should I follow the same colours ?
1977 Clubman
Users browsing this forum: Bill B and 77 guests
