It is currently Fri Jun 27, 2025 12:42 am
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Mar 21, 2006 5:26 pm
My conversion was easy and have not cut anywhere in the engine bay thats a 3cyl diahatsu and turboed should make 100hp
the suzuki alto is even easier check out some of the pics on turbo orangie's page of his subframe
57 Morris minor
88 Rover Mini
PostPosted: Tue Mar 21, 2006 5:49 pm
i like the alto worx.... the look better when they're tatty :)
PostPosted: Tue Mar 21, 2006 6:10 pm
Die Die Die!!
yeah that looks alright... dont spose you would know the features of the engine ? such as fuel injection, a/c...
PostPosted: Tue Mar 21, 2006 6:11 pm
gzevan's conversion would be my pick ,thats a great conversion.Although ive only had to cut my inner gaurds out on my honda city turbo conversion.
PostPosted: Tue Mar 21, 2006 6:16 pm
Die Die Die!!
i just need a pretty straight forward conversion, as i was considering buying a 1275.. it will be just as easy to get something else, but i dont want something thats gonna keep me off the road for long i basically wanna put it in and be done...
PostPosted: Tue Mar 21, 2006 6:41 pm
seriously.. nick isn't it?... .the simplest thing to do would be to put the 1275 in...
PostPosted: Tue Mar 21, 2006 7:01 pm
here is a pic from above to show how compact my motor is 8)
it would fit in a roundie with front mounted radiator :D
57 Morris minor
88 Rover Mini
PostPosted: Tue Mar 21, 2006 11:18 pm
see and its a good motor - the engine itself says so
PostPosted: Wed Mar 22, 2006 12:11 am
Die Die Die!!
haha
...wat are its specs ? power steering , a/c ?
PostPosted: Wed Mar 22, 2006 4:35 am
The TIG
If you are wondering about the engine I used here is a little info.
Donor 1988 Suzuki Forsa Turbo
Cylinders 3
Valves 6
Displacement 1.0l (993 cc)
Horsepower 70hp @5100rpm
Torque 107 ft.lbs @3500 rpm
Compression 8.3:1
Fuel System EPI - Multi point electronic petrol injection (MPI)
Turbocharger Spec RHB32 Parts 3T501 with intercooler
Gearbox 5 speed manual
My particular donor did not have a/c but it was available on others. 150 hp is possible without going to crazy. 200+ is possible with some major mods.
I converted the cable operated clutch to use the stock Mini master cylinder and slave cylinder.
Hope this helps, if you have any more questions I'd be happy to answer them if I can.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Wed Mar 22, 2006 11:14 am
Mines a twin cam 3cyl with 12valve head and efi
989cc with 5speed and cable clutch converted to hydrolic
Puts out about 62hp with 50kgs less weight
57 Morris minor
88 Rover Mini
PostPosted: Sat Mar 25, 2006 12:29 am
I think this is about as compact as you can get it.
hyabusa based but with reverse gear
prices are steep but not ridiculous.
cheapest option is under thousand UKP butyou will have to supply a donor engine. but they can supply a new 1300 stock as well. 205 HP/130lbs/ft.
Up to a full bonkers 1300 turbo with upto 340 HP :shock:
but it can be chain linked to a torque biasing LSD..or gear driven. but that would be harder to place..
the ram air box is a bit too much so maybe you only get 180HP :wink:
Oh they make a V8 too..88 kg dry weight !!
no time to finish me bleedin car ..
1982 Blue-White Roof.
http://aseriesmodifications.wordpress.com/
PostPosted: Sat Mar 25, 2006 8:52 am
Mien
Yun, you just made me wet myself!!
PostPosted: Sat Mar 25, 2006 10:27 am
Seriously, i know alot of people just throw questions arond without truly considering it, but how about you learn a bit more about basic engine stuff, rather than jumping straight in at the top of the list.
It's evident in your questions that you don't really know what your talking about (i mean why are you even asking about power steering and a/c?) and that's fine, asking questions is the way to learn, but it seems like even the foundation isn't there to teach you, it's like trying to make you run when you havn't even taken a step.
PostPosted: Sat Mar 25, 2006 11:06 am
Yeah I would have to agree with Mini Mad, try sourcing a 1275 drop it in the engine bay and work on the engine a bit and I think you will become aware just how difficult a process an full non BMC/Austin engine conversion is. Most of the guys on here doing conversion I would suggest have at least a few years of stuffing around with the A series and cars in general before attempting this conversion.
Matt
