It is currently Sun Jul 20, 2025 8:40 am
 Post subject: Please help ASAP
PostPosted: Fri Oct 01, 2004 10:48 am
I just bolted the brake master cylinder back on and now the bottom brake pipe wont screw back into it
it came with red bit of plastic type plugs in it and i removed them and the top one fits but the bottom will not screw in tried for ages
whats the problem is the bottom hose a different size thread
 Post subject: Re: Please help ASAP
PostPosted: Fri Oct 01, 2004 10:51 am
which master cylinder m8 ?
lookin for another clubby
PostPosted: Fri Oct 01, 2004 11:00 am
dual brake master cylinder top pipe fits bottom wont
i was meant to take the plastic plugs out right and the thread seems to small on the bottom one its been fully overhauled
if its a dual master ( which im guessing , you MAY be trying to put the pipe in the sensor hole ? because they are all the same thread
also us the pipe union pushed all the way up on the pipe ? try lubricating it with a little brake fluid
PostPosted: Fri Oct 01, 2004 11:03 am
they havent cut new threads have they ? yeh the plugs have to come out
PostPosted: Fri Oct 01, 2004 11:08 am
yes they have cut new threads by the look very new all though if there the same size it should be ok but it wont i will go try again
PostPosted: Fri Oct 01, 2004 11:56 am
i got it on but the thread doesnt go all the way when doinng it up
like the nut bit is a little away from the master cylinder is this ok the pipes seem to be in ok and no leaks but still no pedal have to bleed them before any pedal
Users browsing this forum: No registered users and 69 guests
