It is currently Fri Jun 20, 2025 9:21 am
Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13  Next
PostPosted: Tue Oct 11, 2005 7:27 am
sorry Beau. I don't have the link as the Gemini Forum was hacked and is in repair.
PostPosted: Sun Mar 26, 2006 3:00 am
Okay, I may have already posted this somewhere on Ausmini in the past, but I cant be bothered searching for it.....
For anybody who may be contemplating a Supercharger installation of any kind, your best investment will be buying a book like this one.... and then reading it twice.
RRP $77 + $7.50 postage....... at Pitstop Bookshop in Perth
Or on sale for $69 + $6.50 postage at COMPUTEROUTPOST Bookstore in Sydney
Description
Corky Bell, the author of the best selling Maximum Boost, has done it again with the publication of Supercharged! Design, Testing and Installation of Supercharger Systems.
Superchargers have become one of the most popular performance bolt-on products for all engine sizes?from the diminutive, but powerful, Honda and other import four cylinder engines, to Porsche and BMW engines, and Detroit?s V6s and V8s.
# Contents :The Purpose of Supercharging.
# Acquiring a Supercharged Vehicle.
# The Physics of Producing Power.
# The Balance of Heat.
# The Roots Supercharger.
# The Centrifugal Supercharger.
# The Screw Compressor Supercharger.
# Intercooling.
# Intake Manifold.
# Electronic Fuel Injection.
# Events in the Chamber.
# Secondary Components.
# Mounting the Supercharger.
# Drive Mechanisms.
# Preparing the Engine.
# Testing the System.
# The Outer Limits of Power.
# Designing a Supercharger System.
# Implementing the Design.
# Installing a Supercharger Kit.
For an enthusiast to be able to bolt on a system that not only works but is reliable has always been a ?mystic art.? This is no longer the case! Clear and comprehensive information on how to select, size and install a successful and reliable supercharger system is provided in full detail.
For anyone interested in installing a supercharger system, or just learning about them, 'Supercharged! Designing, Testing, and Installation Of Supercharger Systems' is a must have book!
I thought I had everything covered before I read this book - I was very wrong. The chapter about THE BALANCE OF HEAT was worth every cent of that book. I cant stress how important it is to do your research.... it'll save you money in the long run.
PostPosted: Sun Mar 26, 2006 8:36 pm
Amazon have the book for about 22 usd which is about half price.
http://www.amazon.com/gp/product/083760 ... oding=UTF8
PostPosted: Wed Apr 05, 2006 8:04 pm
can some one help me i need to know what this part is on the manifold
PostPosted: Wed Apr 05, 2006 8:23 pm
It looks like the pressure release valve.
This basically is a safety device to stop the mainifold over pressuring and blowing to bits.
Much like a blow off valve in a turbo setup
Thanks
Bernard
PostPosted: Thu Apr 06, 2006 12:39 am
Yep.... and it is spring loaded.
The only thing that worries me is "releasing" the boost at that location, above the exhaust. Remember, the fuel is already in the system before that point..... so the valve is releasing air AND fuel when it opens up.......
PostPosted: Thu Apr 06, 2006 7:47 pm
wouldn't you plumb it into the intake / air filter? what does Ben recommend ??
PostPosted: Sat Apr 08, 2006 5:59 pm
This valve only opens if there is a backfire and venting to atmosphere is OK as when a backfire occurs the fuel in the manifold is already burn (by backfire igniting it) and you get a little flash from valve , if valve is not fitted it will try and turn the supercharger backwards and damage it or the belt. The valve is set to blow off at a higher pressure than normal woking pressure and never opens during normal operation so fuel is not allowed to excape.
4efte powered Clubman
supercharged 998 race car
PostPosted: Sat Apr 08, 2006 6:47 pm
oh yeah?. what would you know?
:P
PostPosted: Sun Apr 09, 2006 9:40 am
really good kit i would reccomend it....has lots of things in it and makes for an easy installation...
i got one on my mini
http://www.ausmini.com/forums/viewtopic ... 512#243512
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
PostPosted: Fri May 19, 2006 6:14 am
could it be bolted up with the engine still in the bay? i dont mind pulling her out ahain really just dnt wanna damage my paint lol (we went a bit over board with the pearl and its a P***K to touch up!!)
really keen on a kit if i can get hold of 92 tho!!
PostPosted: Mon May 22, 2006 7:40 pm
Yep can be fitted to an engine still in car just have to remove crankshaft pulley to fit new one and remove extractors for slight modification.
slo_firo I haven't recieved anything
PostPosted: Fri Dec 01, 2006 10:48 am
hey guys and gals
im looking at getting one of these sc12 kits for my car and was wondering what problems people have had if any, and also any recomendations that need to be done or changed on the kit?
hope be back on the road soon with a blown 1275.
PostPosted: Mon Dec 04, 2006 5:04 am
no problems, well the hardest bit was bolting the charger up and getting the extractors bolted on while all in the car,
got mine going on the weekend (finally got the rest of the exhaust made) now lets see how long my clutch lasts
really good kit tho, it really cuts down all the hard work and only needs minimal mods to get it all on and working
backyard performance............. Aint it the best
PostPosted: Mon Dec 04, 2006 3:17 pm
Mine is coming soon! I've got my carbie and supercharger sorted and 92's says he's started my kit, although it will be a while, I can't wait! The SC-12 are becoming a bit thin on the ground, I got mine through toymods, but not easily. Had to get it couriered from Sydney.
Users browsing this forum: No registered users and 24 guests
