It is currently Tue Aug 19, 2025 8:52 pm
 Post subject: 940 head on smallbore?
PostPosted: Sun Mar 26, 2006 3:48 pm
Can anyone tell me if I can fit a 12G940 will fit onto a 1098 engine?
I've heard it can be done what needs to be done to make it fit? Do I need to get my block pocketed?
PostPosted: Sun Mar 26, 2006 4:03 pm
Yes you need to get the pockets for the block....HOWEVER,
I ran one on a 998cc and had it on there for 12 months without the pocketing. However you cannot rev it hard and definitely STD cam and rocker gear. Saying that though - it went like a cut snake until I decided to go back to a 12G202 instead.
Dave Hamills book "How to Powertune BMC/Leyland 998cc" is a good reference.
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sun Mar 26, 2006 4:19 pm
If you run stock rockers and a cam with less than .290" lobe lift, you can get away without pocketing a 12G940 (or a 12G1316) on a road motor. As long as head is hardly decked and ex valves are sunk in a bit (as most are these days).
There's an article by Keith Calver in Feb 06 issue of MINI Magazine.
I did one (on 1100 bored to 1220cc) back in 1968, with a 544 cam and pocketed block, yes it did go rather well... 8)
PostPosted: Sun Mar 26, 2006 4:55 pm
It's just got one of them kent 266 cams in it. I'm running std rockers. The head has been decked .10thou. Do you think this would work without pocketing? Where can I get a block pocketed if need be?
PostPosted: Sun Mar 26, 2006 5:31 pm
Miniot!!
That's Des Hammill 8)
Lillee - 1969 Morris Mini K
PostPosted: Sun Mar 26, 2006 6:26 pm
Yes it should be OK without pocketing.
Graham Russell could do it, if motor is not in car.
I did mine IN the car way back then, kazjim on here did his recently the same way, using a die grinder and stones.
Buy Des Hammill's book and go for it if you want, it has step by step instructions- but if it's not going to be over-revved, you should get by without it. :wink:
PostPosted: Sun Mar 26, 2006 6:41 pm
What would you consider over revving? Like above 5000?
Thanks everyone for the help.
PostPosted: Sun Mar 26, 2006 6:53 pm
with decent double valve springs, 7000-7500. :wink:
PostPosted: Sun Mar 26, 2006 7:58 pm
68Delux wrote:
Miniot!!
Des, Shmes - who cares...its a good book!...lol
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sun Mar 26, 2006 9:25 pm
KAZJIM....
thread here...
http://www.ausmini.com/forums/viewtopic ... ght=pocket
PostPosted: Mon Mar 27, 2006 6:59 pm
I never knew you could do it yourself with a grinder. Learn something everyday.
One last question. Would I use a 1275 head gasket, since I'm using the 1275 head. Or do I stick with the 1098 head gasket?
PostPosted: Mon Mar 27, 2006 7:00 pm
Sexual 8)
And thats how to make a 998 really go :wink:
PostPosted: Mon Mar 27, 2006 7:06 pm
I did mine in car with a die grinder and yes use a 1275 head gasket
4efte powered Clubman
supercharged 998 race car
PostPosted: Mon Mar 27, 2006 7:16 pm
The 1275 BK450 gasket is the best one these days, but KC says watch the front water holes near #4 cylinder.. you may need a 12mm plug screwed into one of them. Details in Feb 06 issue of Mini Mag.
Rule of thumb is you always use the gasket that belongs to the head type. A smallbore gasket will not seal all the water holes in the head. :wink:
Users browsing this forum: Bing [Bot] and 19 guests
