I had problems shifting when cold (-3?) when running thick oil in my standard Morris 1100 (I was living in the Blue Mountains at the time) I switched to HPR30 and it cured the problem. I now live in Goulburn and it is even colder (it gets down to -7?)
Looking at the data sheets for the oils....
Penrite HPR50. cold cranking viscosity, cP at -5?c = 10,565
Penrite HPR30. cold cranking viscosity, cP at -15?c =8544
Castrol Edge 22w50. cold cranking viscosity, cP at -10?c =9500
Castrol Magnatec. cold cranking viscosity, cP at -25?c =6600
Looks like HPR30 is not too bad but Castrol Magnatec would be better at very cold temperatures. Castrol Edge would be allright if you have a semi race car and you live in Sydney.
