It is currently Sun Jul 20, 2025 6:31 pm
PostPosted: Mon Oct 04, 2004 12:44 pm
What jacking points are safe to use
i know the actually ones that came from the factory underneath but where else, i have seen people putting the jack under the front arm type thing the biggest one the goes to the wheels sorry dont know what its called is this safe to use
you know the arm type thing goes from like the subby where the engine is to the wheel
PostPosted: Mon Oct 04, 2004 2:39 pm
If you are jacking under the front, the best and safest spot is the subframe, next to where the bottom arms you've just described are attached.
Same deal at the back- under the subframe, either side.
Don't jack under the floor... :cry: I've seen jacks disappear... :lol:
PostPosted: Mon Oct 04, 2004 3:34 pm
thats what i was worried about
what i was talking about are the lower control arms i think are these safe to use with stands or jacks
PostPosted: Mon Oct 04, 2004 4:45 pm
Not as safe as using the subframe, as they are not level- so be careful.
Whatever you do, don't ever jack under the front tie bars.. that (& towing from there) is what bends them! :cry:
PostPosted: Mon Oct 04, 2004 8:50 pm
i know the tie bars are too small but i was just thinking that the control arms would be strong enough but i will use the subby next to it
PostPosted: Mon Oct 04, 2004 9:05 pm
I just cheat and drive mine along the gutter. I can scrape my chest under the sump. I can get all the way under the car then, and I'm not a small bloke by any means
"He's always been a dickhead, He always is a dickhead, He will always be a dickhead. So stop complaining when he acts like one."
PostPosted: Mon Oct 04, 2004 9:21 pm
I have a ning nong of a time trying to jack up my car.
I can't get the trolley jack and a wheel stand under the subframe (approximately underneath the bottom-arm joint) at the same time. It just always ends up being a lame f**k around.
I put a nice crack in my drivers side floor pan using the factory spots a couple months ago.
dewey
dwightgunning.com
PostPosted: Mon Oct 04, 2004 9:26 pm
yeah i reckon ill just buy some ramps from repco
the factory jack points scare me :shock:
PostPosted: Mon Oct 04, 2004 9:58 pm
I have three clubman bodys in the back yard ALL of them have damaged floors where some nitwit has jacked them up by the front floors.
PostPosted: Mon Oct 04, 2004 10:17 pm
yeah thats no suprise one of mine has a slight bump under there
PostPosted: Mon Oct 04, 2004 10:27 pm
Happens to floors all the time- tyre places, workshops with cable hoists.. :x
When I go to buy tyres, I use my own jack.. AND wheel brace.. :shock:
PostPosted: Tue Oct 05, 2004 9:37 am
I use a combination of jacks to get the car high enough to use the trolley jack... I think there's no other way with the mini being so low on the front end...
Lillee - 1969 Morris Mini K
PostPosted: Tue Oct 05, 2004 9:40 am
With my hydro setup to get the trolley jack underneath I lift the car up a bit first, then it will sit higher and the jack fits! Same trick works to get the oil tray to fit under when doing an oil change!
PostPosted: Tue Oct 05, 2004 10:09 am
Real Mini side jack is OK, if in good condition... just don't crawl under car without stands! :wink:
PostPosted: Tue Oct 05, 2004 10:14 am
I've got a real original mini jack, it is classic british build quality - you keep turning it and the car doesn't lift up at all :(
Users browsing this forum: No registered users and 69 guests
