the seal is to keep a nice 'seal' on the fluid, giving it a second skin.
when you run low on fluid, it pops down so that air doesnt get sucked into the pipes
it also stops dust n particles getting sucked in too
if the seal gets sucked down, it means you are using up brake fluid
mine kinda does it, comes out of my front brakes
1. gets soaked by dirt and more dirt when i drive, and i cant see the damage
2. if too much, it goes onto the floor, then i can see a problem
_________________ Inconspicuously Conspicuous
