It is currently Sun Jul 20, 2025 6:36 pm
PostPosted: Sat Oct 02, 2004 6:37 pm
We have spoken about which oil to use in your Mini before,but which coolant ?, if any, is best to use in a Mini, a month or so ago I blew a head gasket, and have only got water in the radiator, at the moment, thanks for any help Tony :D
PostPosted: Sat Oct 02, 2004 6:52 pm
i bought 5L Nulon Concentrated Coolant: $33 a bitch of a price but i have four cars
im not too sure about car companies making auto stuff (eg. Toyota, Honda coolant, engine oil transmission fluid - someone enlighten me on this) so i went with this one
also chose the concentrated coz theres: 1:1 option with water for normal conditions
or 3:2 for extreme conditions
you can vary for crappy side mounted radiators and cast iron blocks
one question: can too concentrated be bad for cooling properties of the fluid?
Inconspicuously Conspicuous
PostPosted: Sat Oct 02, 2004 7:33 pm
Yup, the higher the Ethylene Glycol content, the higher the surface tension of the coolant, and the less contact with the metal of the radiator. Sounds dumb, I know. Ethylene Glycol's quality is that it doesnt boil like water and produce steam which can reach phenomonal pressures at times.
Water Wetter is a saturating agent, and causes the surface tension of the water to relax, which in turn means more contact with the metal of the radiator, and the passing air(which really cools the engine).
Enough Technocrap. If I could get Water Wetter here i'd use it, but I cant so I use 33% Glycol coolant. And yes, I still have overheating problems. I'll see if the bigger carby makes a difference. I reckon the 1 1/4 causes a massive lean out, and gives me all of my drama
PostPosted: Sat Oct 02, 2004 10:12 pm
yeh ive been told to increase the fuel conk in summer
oh and the guy at the auto store told me a year ago: the more concentrated the better
he was also the one who said my 3.4L Prado would take 3.4L of engine oil,
and my 998cc mini would take 998cc of engine oil
PostPosted: Sat Oct 02, 2004 11:00 pm
this stuff is excellent - expensive, but excellent. My mechanic mate who preps rally cars and all sorts of things gave me a bottle before I took my Cooper S to Winton, ran cooler all day at 6500-7000 rpm than it did driving around town a couple of days before
http://www.minimania.com/web/Item/WATER ... Detail.cfm
plus it's the oinly coolant you're allowed to use on a race track - not that they check for it on club sprints with road cars
PostPosted: Sat Oct 02, 2004 11:45 pm
Quote unquote Dr mini "Anything will do so long as it isn't plain water" :wink:
PostPosted: Sat Oct 02, 2004 11:56 pm
what about water with abit of salt
or even better, acid!
looks like ive stumped the Doc!
PostPosted: Sun Oct 03, 2004 10:16 am
There he goes, misquoting me again.. :lol: :lol: :roll: :wink:
I use Nulon concentrated glycol in mine too, 25%-33% mix. You don't need more. And I change it every 2 years or sooner.
Beware of the premixed stuff they sell in stores- some is little more than coloured water.
PostPosted: Sun Oct 03, 2004 10:36 am
Geez, I meant any coolant will do so long as it aint plain water! Gosh Duc, go for it, use acid! :twisted: :roll:
PostPosted: Sun Oct 03, 2004 11:53 am
okay!
PostPosted: Sun Oct 03, 2004 2:02 pm
Dont bother with the new fangled red coloured stuff, its designed for more modern cars. I dunno what the difference is, but it's specifically recommended that you only use the colour coolant that your car originally came out with.
So stick with the ol' green Ethylene Glycol Mix.
And I agree with Doc. 33% - 50% is the best everyday mix.
The original mini owners handbook recommends a 66% mix, but that was more for the antifreeze qualities in colder climates.
PostPosted: Tue Oct 05, 2004 7:54 pm
Thanks guys for all the help, I think I'll go to Supercheap and look for some Nulon concentrated glycol coolant , thanks again Tony :D
Users browsing this forum: Astroblue, Bing [Bot] and 56 guests
