It is currently Sun Jul 20, 2025 11:57 am
PostPosted: Sat Apr 29, 2006 5:21 pm
Die Die Die!!
ive noticed in a few pics that some mini's have a left hand side stick out of their steering rack (assumedly for windscreen wipers) i was wondering if it was a rover.. and weather i can put on into my morris/clubman and if anyone has done it how hard it would be... as im getting tired of having to watch the road and try and feel for the windscreen wipers as i cant see where im driving :S ..damn rain..
PostPosted: Sat Apr 29, 2006 6:02 pm
OK I reckon I know what you mean BUT you've got your terminology wrong.
The steering rack is the horizontal portion under your feet when driving. It is a rack gear and is moved by the pinion gear at the end of the steering COLUMN. Now the column, to which the steering wheel attaches, does come in several varieties. Some of these have two stalks.
Twin stalk columns were standard in late Mokes and all Rover minis from about 1978. The Australian variety had the indicators on the right, the Pommy ones have the indicators on the left. The indicators, horn and wipers are controlled by the column stalks but the head lights are sitll on the dash.
Late 90s air bag equipped cars have intermittant function for the wipers so the switch has one more position. They also have the head light switch on the column.
You can interchange them all so long as you get the whole assembly, not just the stalks and shroud. Air bagged cars have different steering wheel splines so earlier wheels don't fit.
M
M
PostPosted: Sat Apr 29, 2006 6:15 pm
Die Die Die!!
yep i wasnt really sure wat to call it... im alot clearer now tho.. aint it obvious ive never actually pulled one appart (yet).. yeah as i was saying its a bitch to have to reach for the wiper button (led alone dangerous)... so i was looking to see if its interchangeable :)
PostPosted: Sat Apr 29, 2006 6:24 pm
If you are handy with powertools and wiring, you could adapt something from a different car. I got the stalks from an Excel, they have the usual washer, indicators, headlights (high and low) and 2 wiper speeds plus 5 intermittant levels, if you adapt the excel wiper motor too. :D
PostPosted: Sat Apr 29, 2006 6:36 pm
I've had no probs reaching the wiper switch, since I put inertia reel belts in the front of mine. 8)
Pity I can't do Barney's too, the friggin' early Clubby seat base (in a roundnose shell) fouls the reel.. :cry:
PostPosted: Sat Apr 29, 2006 6:42 pm
Die Die Die!!
hmm thanks for the idea barney.. yeah im good with powertools.. wiring should be too complicated... ill look into that option.. but late model stalks seems easier...
PostPosted: Sat Apr 29, 2006 7:27 pm
Running Honda gear in one of mine, doesn't really matter, they all do the same thing.
I actually saw you can buy a generic one from Supercheap for about $60. Not a bad idea for all new switch gear.
PostPosted: Sun Apr 30, 2006 7:42 am
i can reach mine while tightly belted in...
mind you... i musn't have kangaroo arms, like yourself, doc... :)
PostPosted: Sun Apr 30, 2006 2:02 pm
Die Die Die!!
i can reach it its just a matter of going 60km (or watever speed) its just started pouring down so i cant see out the windscreen... im sposed to be looking where im driving so i dont crash yet i find myself feeling or tempted to be looking down to find some wiper switch...
