sherman67 wrote:
i have the body number stamped on the radiator shroud it may be on the boday as well on the firewall but not sure cause its cotted in many layers of wo knows what. but the radiator shroud has been cut off but i still have it all i need to do is weld it back on but is there any way of telling what year it is from that???
There is no formal register in Oz like the Heritage one in UK.
If you post the body prefix and most of the number here, people can make an educated guess.
Number sequence started at 501 for each body type- eg 850, Mini Deluxe, Mini K.
Original colour (if known) can help pinpoint the year too.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
