It is currently Sun Jul 20, 2025 3:20 pm
PostPosted: Sat Oct 09, 2004 9:02 pm
I had a look at a mini van 2day... the the motor has been taken out and every thing has been taken off it, just the block left with a few boxes of parts--the bloke told me it's all there :roll: i'm woundering how hard it is to put it all back together and wire it all up etc? i'm not very mechanically minded :cry: and would only have a manual.. or should i get it done buy a pro or should i buy a engine all ready together and use this 1 as parts??
'75 windowless van
~LOLA~
PostPosted: Sat Oct 09, 2004 9:21 pm
You could probably, get the motor back in the car, but if you don't know how to build an engine, i really wouldn't suggest it. Tollerences are very important in a rebuild, and there are parts inside an engine if put in the wrong way (thrust washer's) that can completely distory an engine in a very short time. I would suggest either by another complete engine to throw in. or have someone build it for you.
Aaron
PostPosted: Sun Oct 10, 2004 12:37 pm
The wiring bit would be easy. apart from the spark plugs and ignition wiring, there is hardly anything that goes to the engine LOL. Maybe a few instrument wires.
"He's always been a dickhead, He always is a dickhead, He will always be a dickhead. So stop complaining when he acts like one."
PostPosted: Sun Oct 10, 2004 8:04 pm
sounds like he has an engine which is pretty much together just needs the extras back on carby , alternator, starter, dist, etc is this correct if so and you know the engine is in reasonable condition inside then not a huge job
IS this right then pay someone who knows about minis to do it wont cost much couple hours labour
