It is currently Mon Jul 21, 2025 4:59 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Post subject: Re: Timing Chains
PostPosted: Mon Oct 11, 2004 1:24 pm
CPOCSM wrote:
Thanks mate - saw one in one of those pommy mags - looked pretty flash. Going out to finally put the 1.5:1 "S" rocker assembly on the clubby - Wife is going to love me for that...lol
Skins
Don't forget to open the rockers up by .003" approx, or it will be a dog down low.
eg for a Kent 276 etc run .018 not .016".
I run my Russell RE-13 at .020" with 1.5s, 'coz that's what the man said.. 8)
PostPosted: Mon Oct 11, 2004 6:30 pm
i'm not sure what you mean by a half hemi on the crank hole but i guess that means i dont have one
can i pull that end plate off with the engine in the car.. i cant imagine why not but i better make sure that i wont gut something i shouldnt if i try, and i do have a drill press... will i require a gasket that i didnt buy if i take that plate off?
also how high is the oil level? does it come as high as the crank.. am i gunna make a mess if i take that plate off?.. i'ver never seen an oil level that high but then ive never seen rubber uni joints before (except for in my grandfather 37 crysler, actually i think his is leather)
PostPosted: Mon Oct 11, 2004 6:35 pm
The 2 bottom holes in the plate (under the crank) need countersinking, then you use csk Unbrako screws to hold the plate on. The standard hex screws there will foul the wider chain.
It CAN be done in the car but it's easier with it out. Not much room for a power drill and CSK bit in there, and it's hard to see too. :wink:
PostPosted: Mon Oct 11, 2004 6:53 pm
i've been told that i can just wretch the engine end plate out and couter sink the plate then put the plate back in and leave the engine where it is
PostPosted: Mon Oct 11, 2004 7:15 pm
True. :lol:
