It is currently Mon Aug 04, 2025 11:25 pm
Post new topic Reply to topic  [ 81 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue May 23, 2006 5:45 pm
NAV-MAN
_666_ wrote:
thats a nice finish harvey.. but i was hoping for mine to be shinier
He hasn't finished yet. That will gleam with some tlc
PostPosted: Tue May 23, 2006 6:17 pm
I reckon black would be do-able, but you'd want to throw some metallic in it as a pure black colour WILL show all the lack of prep - pretty much impossible to do well without a big garage, lots and lots of time and patience. I think you'd probably regret it, whereas making it metallic will hide some of the inevitable flaws. And look more professional and 'show worthy'.
Incidentally, next time you're walking past a Ford XR6 in black (or any pure black car, new or old), have a good look at the paint. The reflection will show that the whole paint job has orange peel. Try the same with a metallic car - the finish looks better, much better.
PostPosted: Tue May 23, 2006 6:22 pm
even better, paint it matt black - hides everything, then throw on clear with some house of kolor flakes in, looks awesome! BLING but subtle. 8)
PostPosted: Tue May 23, 2006 6:39 pm
Die Die Die!!
fiddle sticks no im not painting it matt black.. its definatly gloss.. matt looks like its not finished...
and yeah i know he hadnt finished it but i meant so far it looked good no glitchy bits or uneven bits...
PostPosted: Tue May 23, 2006 6:42 pm
NAV-MAN
Proper panel prep prevents piss poor paint jobs :D
The final finish will reflect the panel prep underneath
PostPosted: Tue May 23, 2006 6:48 pm
Die Die Die!!
indeed so ill be taking my time...
PostPosted: Tue May 23, 2006 7:50 pm
Good luck with it all I hope it goes well for you, I couldn?t be stuffed doing mine so I paid for it but each to there own. When do you plan to put the paint on it?
PostPosted: Wed May 24, 2006 12:41 am
Die Die Die!!
as soon as i can afford it.. the shell wont be touched for another month at least i rekon...
PostPosted: Wed May 24, 2006 9:15 am
oh yeah sorry i forgot to mention, when you buy a compressor the thing you want to look for is how long it takes to build up pressure, not ness how many horse power, eg. my compressor is 2.5hp and 40L, but it does 112L per min but i've been told that you will prob need one that does 150-200L per min.
we have 2 hp ones at work that build up pressure faster then ones with 2.5hp....always check to see how many litres per min it does
PostPosted: Wed May 24, 2006 9:24 am
arround 10cfm is good...
another (cheeper) option is to buy two cheep 2hp 40L compressors for about $100 each, join the outlets together with a 'T" piece and two short leingths of hose, attach a moisture trap and pressure regulator at this point (run both compressors at full pressure), attach hose to end of regulator, easy. 4hp, 80l and arround 220 litres per minute.
Oh, and its cheeper than buying a single compressor of the same output...stupid huh.
PostPosted: Wed May 24, 2006 12:30 pm
Die Die Die!!
intersting jbeanz...
PostPosted: Wed May 24, 2006 1:09 pm
im a very interesting person....hahah na just a poor stuident with way too many cars with bad paint.
PostPosted: Wed May 24, 2006 1:17 pm
10cfm is only good if the gun you're using doesnt require more than that
With what i use, 10cfm is crap
PostPosted: Wed May 24, 2006 1:56 pm
jeez, what kind of gun are you using?
PostPosted: Wed May 24, 2006 2:11 pm
:idea:
Users browsing this forum: No registered users and 57 guests
