It is currently Fri Aug 08, 2025 10:58 am
PostPosted: Tue May 23, 2006 8:42 pm
Okay so since we got the motor in, me and dad have been spending countless hours in the shed getting all the panels right. The roof took the longest getting all those little bumps out..bog, sand, bog sand etc. etc. you know how it is.
so with the advice of my neighbour the spray painter we have been working away with the broadfile and the 'buzzer' (the off centered circular air powered sander) we had it to the stage where it was all pretty straight.
then the other weekend we had him spray about 6 coats of primer putty all over, and weve been spending ages sanding it all back. We are now up to sanding with 800 sandpaper so its all getting very smooth. Heres a pic of it a few days ago:
Now we have almost sanded the whole car back to 800 and its getting very close to being sprayed..I hope!
So hopefully more updates with more pics soon 8)
PostPosted: Tue May 23, 2006 8:44 pm
Wait till u pull back the newspaper covering the engine bay and realised you didn't have a perfect seal around the edges... :lol:
Looking good.
So we have Peanut, you and myself all very close to being on the road.
Awesome :)
PostPosted: Tue May 23, 2006 8:46 pm
Die Die Die!!
what HP compressor are you using for all this ?
PostPosted: Tue May 23, 2006 8:51 pm
mmmmm close to driving mini ......mmmmmm.....swweeettt
how far will yours be off from being on the road Aussie?
PostPosted: Tue May 23, 2006 8:52 pm
weve got a really old (unknown horsepower) compressor, aswell as a 2hp one which is brand new.
They both power the spraying guns fine but the buzzer requires a constant really high pressure which both compressors arent quite up to. So unfortunately we had to keep swapping the hoses which was a bit of a pain but we got the job done.
PostPosted: Tue May 23, 2006 8:53 pm
Its really hard to tell...very hard to put a date on it because as all you guys know things never go to plan! There's bound to be plenty of hold ups on the way
PostPosted: Tue May 23, 2006 8:57 pm
Yes tell me a bout it mine was only ment to take 6 months but it has turned into nearly 2 years.....
its also the tank size you need to consider with compressors
PostPosted: Tue May 23, 2006 9:03 pm
bog, sand, bog, sand, bog, sand. I'm hearin ya!
Worst job EVER!! but all worth it in the end.
It's looking good, hang in there.
Take it easy, & if it's easy take it twice!!
PostPosted: Tue May 23, 2006 9:47 pm
good work there mate it will be worth it in the end! good on ya for sticking with it.
PostPosted: Wed May 24, 2006 10:07 pm
true, but theres always hand sanding to do somewhere else when you are waiting for the compression to build up!
There's the chance of rain for sunday so might not be getting sprayed this weekend unfortunately - but theres still chance!
PostPosted: Wed May 24, 2006 10:09 pm
lookin good keep it up might have it ready for minis at the mill hey :wink:
PostPosted: Wed May 24, 2006 10:25 pm
wow i didnt think you could get a mini in primer that shiny. good work son
Inconspicuously Conspicuous
PostPosted: Wed May 24, 2006 10:50 pm
lol its sanded back to 800 - its shiny because its wet from all the wet rub and wiping all the dust off :lol:
