It is currently Fri Aug 08, 2025 3:58 am
PostPosted: Wed May 24, 2006 9:06 am
I dont have hazard either in my LS 1275 is that standard or did thery forget to equip them, lol? if in doubt if you have to pull over to the side of a road pop ur hood and leave a blinker on I say.
PostPosted: Wed May 24, 2006 9:12 am
Shouldn't be too difficult to make a hazard circuit just use another indicator flasher can except it's wired to indicators on both sides. Easy to wire in if you set it up right next to your existing indicator can.
PostPosted: Wed May 24, 2006 9:33 am
poeee wrote:
I just put it in reverse! They don't flash, but the next best thing!
so which bit is meant to light up?
PostPosted: Wed May 24, 2006 9:44 am
if I'm not mistaken and froma rough memory guess its the brakes lights light up for reverse but I could be far accurate
PostPosted: Wed May 24, 2006 9:57 am
No - its the indicators that light up but only on cars that have a reversing light switch on the gearbox that ios activated when you select reverse. Most rod-change systems have that.
No, its not easily transferible to early gearboxs
A good autoelectrician should be able to give you a set of hazard flashers quite easily and cheaply. They also could give you reversing light as easily but i think its illegal to have reversing lights that are not gearbox controlled.
PostPosted: Wed May 24, 2006 12:28 pm
Die Die Die!!
well thats pretty crap
PostPosted: Wed May 24, 2006 1:24 pm
I have hazards on my 71 Clubby but I did use the full Starlet loom which made that bit alot easier. Now to hook up the reverse?
PostPosted: Thu May 25, 2006 12:00 am
I wired in the Hazard light section out of an early two door Range Rover,( this wiring uses bullet connectors ). This is similar to most early British cars and uses two flasher cans, original one for normal blinkers and the switch cuts power to this and powers the other square one ( flasher can ) for the Hazard lights when selected . My bedford van uses this circuit. I figured I was Small and White and in Fog no one would see me. Now I have the big red switch which flashes like a Christmas tree........ very Blingyyyyyy.
Steve
68 Deluxe. All the Options and Mods. Bling-Bling.
PostPosted: Thu May 25, 2006 6:39 am
Yes it is Mike, you just replace the gearbox's reverse gate detent hex plug (below the oil filter) with the reverse light switch and plunger, as used on late Mk2S etc. :wink:
Bit of wiring, and Bob's yer aunties's husband. 8)
