It is currently Mon Jul 21, 2025 1:52 am
 Post subject: Tachometer
PostPosted: Wed May 31, 2006 11:53 am
Hi all
Looking at buying a Smiths neg earth tacho for my A+
Presume this is the correct tacho to be looking at can anyone confirm and are there better models than others in the Smiths range??
PostPosted: Wed May 31, 2006 12:01 pm
that should do as long as it suits a 4 cylinder? really its a personal choice as to what you like the look of best? smiths guages always look right in a mini though! :D
PostPosted: Wed May 31, 2006 12:43 pm
any tacho will go onto the mini as long as you can switch it on to four cylinders. smiths guages are awsome, ive got them (all except the tacho funnilly enough) and they are great!
PostPosted: Wed May 31, 2006 12:51 pm
Smith Guages look the part, but most i've seen aren't terribly accurate (unless they have been rebuilt)
They don't seem to have much in the way of dampening and the needle wanders all over the place.
I can rev my car in neutral to 4-5000rpm and my autometer sportcomp tach is smooth and accurate and get's to the peak rpm well before the stock smiths tach does (though it does get there it's just delayed a bit).
PostPosted: Wed May 31, 2006 1:35 pm
autogague....
has 4 gagues in one
PostPosted: Wed May 31, 2006 5:16 pm
harvey69 wrote:
autogague....
has 4 gagues in one
Maybe if you are Krusty the Clown.
PostPosted: Wed May 31, 2006 7:49 pm
i was thinking of getting one of them (as above) does anyone have any pics of them in a clubby on the top dash pad
PostPosted: Wed May 31, 2006 8:40 pm
there is a mini on ebay at the moment....... Mini mayhem i think its called...
it has a monster tacho on the top door pad..
cheers.
xo Krusty
PostPosted: Wed May 31, 2006 8:47 pm
PostPosted: Wed May 31, 2006 9:23 pm
I ended up puting VDO Classics in mine to give it that period look
PostPosted: Wed May 31, 2006 10:30 pm
Worth noting that it is illegal to have any guages mounted above the top dash rail..
PostPosted: Wed May 31, 2006 10:51 pm
Hmmm well what about the ricers etc that hang 'em off the A pillar... :lol:
Back in the 60s, it was common and LEGAL to fit them on the dash, so is this an ADR thing, or what?
PostPosted: Wed May 31, 2006 10:56 pm
Yeap, they are illegal too..
I think basically the car is ADR'd with a certain amount of visibilty above the dash and your placing things in the way..that and you can hit your head on them in an accident..
Probably can get them engineered though..
PostPosted: Thu Jun 01, 2006 4:07 am
I picked up a tach out of a MG midget for about $10. I made a pod out of some stainless pipe, and mounted it on the steering column. It looks really good, and since its Smiths it matches everything. I will post pictures of it a little later.
I would recommend going that route.
PostPosted: Thu Jun 01, 2006 6:41 pm
Will an 8cyl smiths tacho work on a 4 cyl engine?
Anybody got some clues?
It does not have 4,6,8 switch
