It is currently Tue Aug 05, 2025 10:59 am
PostPosted: Fri Jun 09, 2006 6:21 pm
Resident Haemorrhoid
trying to workout what needle i need but cant get win su to work
I have a 1098 , single HS4 carbie Factory 3-1 extractors with a 2 inch straight through exhaust with a hotdog muffler
seems to run rich no matter how i set the adujstment thinking i have the wrong needle
can anyone help
mtsmini wrote:
Tombo wrote:
PostPosted: Fri Jun 09, 2006 6:24 pm
I reckon this is a pretty good program http://www.mintylamb.co.uk/suneedle/ or this http://www.teglerizer.com/cgi-bin/needle090db.cgi
PostPosted: Fri Jun 09, 2006 7:27 pm
Hanra wrote:
Now i just need to know how to work it :oops:
mtsmini wrote:
Tombo wrote:
PostPosted: Fri Jun 09, 2006 7:33 pm
The 1st 1 is pretty simple just select jet size 90tho, then put in ur needle type or select another u want to compare to n it will plot it on a graph
PostPosted: Fri Jun 09, 2006 7:41 pm
a 1098 with HS4 should NOT have a 2" exhaust.
I had one, and replaced it because the muffler was shot (bought second hand). I put in a 1.75" with twin box RC40 and I gained a noticable amount of HP and torque.
WinSU says ABY
I was recently running a similar setup in JAM and had a ADS needle. It was PERFECT :wink:
Website: www.justanothermini.com
PostPosted: Sat Jun 10, 2006 5:30 pm
Cheers Anton
i will try that needle :)
whoops a little :oops:
as i measured my Zorst and its 1"3/4 pipe not 2" :oops: :oops:
so i am glad i dont have to replace it :D
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Jun 10, 2006 7:23 pm
Gadgets mini wrote:
Cheers Anton
Let me know what you have, before going out and buying a new one ($20?)
The ADS is a fair bit leaner than the WinSU recommended one for that spec. :shock: The ADS was great for me!
PostPosted: Sun Jun 18, 2006 2:41 pm
finaly got to check out what needle i have its an ADF
its a bugger when work gets i the way of Miniing
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Jun 18, 2006 5:34 pm
ADF is a standard Clubman HS4 needle.
I have a few HS4 carbs, all have ADF needles.
PostPosted: Sun Jun 18, 2006 8:48 pm
has anyone heard of anyone using a 2inch SU on there mini? Whats the Part Name Eg HS4 or HS6
Users browsing this forum: Andosoft and 99 guests
