It is currently Mon Jul 21, 2025 4:37 am
PostPosted: Sat Oct 16, 2004 8:44 pm
does any one know how long is a '72 mini van? i cant find any specs on it :shock: just seeing if it would fit in a box trailer
'75 windowless van
~LOLA~
PostPosted: Sat Oct 16, 2004 9:06 pm
well my bellnose 71 is exactly 3.3m.. 72 is a clubby.. shed be longer
gotta be a big trailer
PostPosted: Sat Oct 16, 2004 10:39 pm
From Haynes manual
Van
overall length = 3298mm
overall width = 1410mm
overall hieght = 1359mm
weight = 621.5Kg
wheelbase = 2134mm
PostPosted: Sun Oct 17, 2004 8:09 am
Marcia wheel base 2150mm long and 1400 Wide (depends on what wheels/tyres U have) with my crappy take measure
PostPosted: Sun Oct 17, 2004 9:13 am
so the clubby is slightly shorter?? that doesnt make any sense
PostPosted: Sun Oct 17, 2004 12:59 pm
The vageries of 70's "precision" engineering!
I understand that the clubbie is a "couple inches" longer in the nose. If your measuring up for a box trailer, then add 100mm at each end, side & top for clearance and you should be right. [you need some space for transit movement]
Just a thought: If you intend drive on/off, leave enought clearance for the driver to extracate.
Cheers Dat
PostPosted: Sun Oct 17, 2004 3:14 pm
nah just leave the driver in there! or if it's a van....they can always just climb out the back doors :wink:
play 3d car games for free
PostPosted: Sun Oct 17, 2004 4:29 pm
van is 4in longer in the wheel base than a standard clubby which is a "couple" inches longer than a roundie :lol:
...its leaking oil... and thats a good sign!
It lets me know that I havent run out yet. :P -Tzi 4-9-04
PostPosted: Sun Oct 17, 2004 5:14 pm
Cheers every1, i might just hire a proper car trailer if i do buy the van :D
'75 windowless van
~LOLA~
