It is currently Mon Jul 21, 2025 6:35 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 12, 2004 12:35 pm
Some ball bearings these days have projections on them and don't use a spacer.
Having the projections no them give them more contact surface area which probably means they'll be less likely to spin on the flange but I have NFI how they will come off now that the two bearings are pressed hard up against each other.
dewey
dwightgunning.com
PostPosted: Sun Sep 12, 2004 2:27 pm
The drive flange will pull out as normal. Then get a thru-tang screwdriver in there at an angle, and give it a tap with a BFH, work your way around it. The bearings will come out OK. :wink:
PostPosted: Wed Sep 15, 2004 10:11 pm
Well the car is back on the ground with brakes bled and ready to rock.
I could only get the drive flange locking nuts done up barely tight with the wheels off the ground. I'm going to go at it with a long breaker bar now. I'm thinking just make it as tight as I can without breaking the bar?
dewey
dwightgunning.com
PostPosted: Wed Sep 15, 2004 10:17 pm
Don't make the drive flange nuts TOO tight, with drum brake CVs. 60Lb/ft torque, if you can borrow a wrench.
Run it for a month then recheck them.
OTOH, DISC brake ones are 150+ but have bigger threads and nuts. :wink:
PostPosted: Sun Oct 17, 2004 10:13 am
hey, sorry about bring back the dead but i would like to know how tight i should do up my rear wheels bearing nut. what torque is it.
JIM
(60 hp @ 5700 RPM) in my old mini.
PostPosted: Sun Oct 17, 2004 11:12 am
Just above yer post.....
60 lb/ft for drums
BLOODY TIGHT for discs
PostPosted: Sun Oct 17, 2004 12:01 pm
He wants to know the rear hub nuts..
But yeah, they are 60lb/ft too, and tighten to next pin hole... according to my Black Book manual.. :wink:
Users browsing this forum: Bing [Bot] and 111 guests
